1. Re: Premiere Video file To Encore
Harm Millaard Jan 22, 2010 12:22 PM (in response to Michael Stehly)If you ask this question, you are better off with exporting as AVI and let Encore do the encoding.
2. Re: Premiere Video file To Encore
Michael Stehly Jan 22, 2010 12:24 PM (in response to Harm Millaard)Thank you!!!
3. Re: Premiere Video file To Encore
John T Smith Jan 22, 2010 12:32 PM (in response to Michael Stehly)I don't do HD... for my SD work, I always export AVI from Premiere and then let Encore do the encoding as part of the authoring process
The automatic setting in Encore will do the work of setting your video to best fit the space you have on the DVD, without you having to know the details of the settings
4. Re: Premiere Video file To Encore
Bill Hunt Jan 22, 2010 3:22 PM (in response to Michael Stehly)Michael,
I would also suggest Harm's method. What I would do would be to Export the Video-only as a DV-AVI Type II, and then Export the Audio-only as a PCM/WAV 48KHz 16-bit file. Import the DV-AVI as a Timeline in Encore, and then Import the WAV as an Asset. From the Project Panel (Encore), just drag the WAV to the appropriate Timeline, where it will snap into place. This saves possibly have issues with muxed files, i.e. one AV file containing both the Audio and the Video.
