3 Replies Latest reply on Jan 25, 2010 10:35 AM by Gregory Lafrance
    error 1009
    GeorgeWS Level 1
      I have an error when my app loads but it works perfectly.
      This is the part I get an error with:
      Bindable] private var myVarietals:ArrayCollection=new ArrayCollection;
      public function doPrompt(event:ResultEvent):void {
      myVarietals = qVarietals.Varietals.lastResult;
      var prompt:Object = new Object();
      prompt.data = 0;
      prompt.label =
      "Select Varietal";
      myVarietals.addItemAt( prompt, 0 );
      varietalfilter.selectedIndex = 0;
      This is the error:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at YMCO/doPrompt()[C:\Users\George\Desktop\Flex Builder 3\YMCO\src\YMCO.mxml:51]
      How can I get rid of the error?
      George
        • 1. Re: error 1009
          Gregory Lafrance Level 6
          What is the exact line of code at line 51 causing the error?
          • 2. Re: error 1009
            GeorgeWS Level 1
            This is my statement:
            prompt.data = 0;
            prompt.label =
            "Select Varietal";
            The last line is 51.
            • 3. Re: error 1009
              So is the line of code causing the error:
              What is varietalfilter and how is it instantiated? If it has been declared but not initialized then that is one possibility.
              You might be able to do this:
              if(varietalfilter != null){
              but you are probably better off finding the real source of the issue.
              If this post answers your question or helps, please mark it as such.
              Greg Lafrance - Flex 2 and 3 ACE certified
              www.ChikaraDev.com
              Flex / AIR Development, Training, and Support Services
