1 Reply Latest reply on Jan 22, 2010 1:16 PM by Gregory Lafrance
    Calling a component.
    Genos_Free
      I want to be able to call a component or components with this code base.
      Using the alerts are ok but I want to be able to call custome components like I would in a viewstack control.
      What do I need to do to accoplish this.
      Thanks in advance.
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/halo"
      initialize="initCollections();"
      <s:layout>
      <s:VerticalLayout/>
      </s:layout>
      <fx:Script>
      <![CDATA[
      import mx.collections.*;
      import mx.controls.Alert;
      import mx.events.MenuEvent;
      Bindable]
      public var menuBarCollection:XMLListCollection;
      private var menubarXML:XMLList =
      <menuitem label="Menu1" data="top">
      <menuitem label="MenuItem 1-A" data="1A"/>
      <menuitem label="MenuItem 1-B" data="1B"/>
      </menuitem>
      <menuitem label="Menu2" data="top">
      <menuitem label="MenuItem 2-A" type="check" data="2A"/>
      <menuitem type="separator"/>
      <menuitem label="MenuItem 2-B" >
      <menuitem label="SubMenuItem 3-A" type="radio"
      groupName="one" data="3A"/>
      <menuitem label="SubMenuItem 3-B" type="radio"
      groupName="one" data="3B"/>
      </menuitem>
      </menuitem>
      // Event handler to initialize the MenuBar control.
      private function initCollections():void {
      menuBarCollection =
      new XMLListCollection(menubarXML);
      // Event handler for the MenuBar control's itemClick event.
      private function menuHandler(evt:MenuEvent):void {
      // Don't open the Alert for a menu bar item that
      // opens a popup submenu.
      if (evt.item.@data != "top") {
      Alert.show(
      "Label: " + evt.item.@label + "\n" +
      "Data: " + evt.item.@data, "Clicked menu item");
      </fx:Script>
      <s:Panel title="Halo MenuBar Control Example"
      width="
      75%" height="75%"
      horizontalCenter="
      0" verticalCenter="0">
      <s:VGroup left="10" right="10" top="10" bottom="10">
      <s:Label width="100%" color="blue" text="Select a menu item."/>
      <mx:MenuBar labelField="@label" itemClick="menuHandler(event);"
      dataProvider="
      {menuBarCollection}" />
      </s:VGroup>
      </s:Panel>
      </s:Application>
