1 Reply Latest reply on Jan 23, 2010 10:39 AM by MamenFLASH$
    Anti-aliasing in exported images
    emarable42
      I had been using Flash MX 2004 previously to create sprites for video games.  In the "export" dialog, there was a check box labeled 'smooth,' which I could un-check in order to retain the hard edges that I needed in order to use the sprites in a game.
      Somewhat recently, I upgraded to Flash CS4.  I have since noticed that, while the 'smooth' checkbox is still there in the "export" dialog, it doesn't do anything.  The exported image is anti-aliased whether or not the box is checked.
      I have tried many different options for exporting, including all different kinds of file types.  Through this experimentation, I also noticed:
      1) that even though it is possible to choose a palette when exporting a .gif, the exported image does not use this palette, and
      2) that if one exports the image as an Adobe Illustrator file, the colors are wrong.
      What I want is to export an image that is not anti-aliased, and uses only the colors that I picked when drawing.  Is this still possible in CS4, as it was in MX 2004?
        • 1. Re: Anti-aliasing in exported images
          MamenFLASH$
          Hello. It may seems quite stupid and maybe it is but, if the checkbox is there, sometimes the problem dissapears reinstaling the software. I had in fact a similar problem with mi 2004 FLASH PROFESIONAL. Sometimes it seems that the aplication has been instaled properly but it hasn't. Good luck. MamenFLASH$
