7 Replies Latest reply on Feb 7, 2010 9:54 AM by Adriepel
    Camera Raw Editing is not enabled
    Chesil
      I am running Photoshop CS4 64 bit in Windows 7.
      Whenever I try to open a .jpg or .tif image in Camera Raw get the message that Camera Raw editing requires that a qualifying product has been launched at least once to enable this feature.
      I am using Camera Raw 5.6. I have installed and copied manually the 64 bit plug-in and non 64 bit to the correct common files directory but cannot get anything other than my raw files to open.
      I have also tried editing preferences but I am having no success at all.
      Thanks in advance for your help.
        • 1. Re: Camera Raw Editing is not enabled
          RouxStudios
          I am having the exact same issue, running CS4 on Windows 7 64-bit.
          Does anyone have any help??
          • 2. Re: Camera Raw Editing is not enabled
            John Joslin Level 6
            I don't have Win7, but I did read that you have to run Photoshop "As Administrator" (via a right-click) at least once, even if you are sole user and administrator.
            • 3. Re: Camera Raw Editing is not enabled
              Chesil Level 1
              Thanks, John, but that doesn't work either.
              • 4. Re: Camera Raw Editing is not enabled
                rasworth Level 1
                I recently installed CS4 on a Windows 7 64 bit system with no problems.  I then applied the latest update which included ACR 5.6.  Again, no issues, and I have successfully loaded jpeg's into ACR (open from Bridge).  So from an existence theorem point of view it works, and I never had to "Run as Administrator".  My system has one user, defined at OS installation, so it has administrative privileges.  I have not enabled the built-in Administrator account.  And I have applied all W7 updates.  Both 32 and 64 bit CS4's are installed, although I have invoked only the 64 bit version.
                Perhaps some more info wrt to your system will provide a clue.  Otherwise my advice is to completely uninstall and reinstall, although normally I am very reluctant to advise such, in my experience hardly ever works because there is usually some other problem.
                Richard Southworth
                • 5. Re: Camera Raw Editing is not enabled
                  RouxStudios Level 1
                  Josh- thanks for the input, didn't work for me either! Opening PS or Bridge to "Run As Admin".
                  Rasworth- I too recently updated to 7 and installed CS4, 64 bit, and applied the latest update to ACR 5.6. I did this same exact thing on my laptop- no issues, but for some reason the desktop has issues, and NOW- won't even open my raw files. Will try some Windows 7 updates and get back to you, but it looks like I am going to be reinstalling CS4 unless someone else has some insight.
                  Thanks guys for the input!
                  • 6. [SOLVED] Re: Camera Raw Editing is not enabled
                    RouxStudios Level 1
                    Acrobat Pro and other Adobe applications starting acting funny, and a friend over in the NAPP Forums suggested it was an activation issue. I never Deactivated my CS4 suite when I updated my Operating System, I didn't think I needed to. I deactivated and then reactivated and all is well in the world of Adobe Suite now!
                    To Deactivate:
                    Open Photoshop
                    Help>Deactivate...
                    It will ask if you are sure, say yes. It automatically closes itself out.
                    To ReActivate:
                    Open Photoshop: it will immediately ask you to type in your serial number or continue 30 day trial.
                    Enter your serial number.
                    Viola! Everything should work just fine now!
                    • 7. Re: Camera Raw Editing is not enabled
                      Adriepel
                      I have tried all of the above ideas and the one given to me by Adobe support and still have the same problem
                      I cannot open in Camera Raw and I cannot use the "Develop Settings" because that same screen shows up
                      Hope that somebody finds a solution for this...?????????.
