4 Replies Latest reply on Jan 23, 2010 6:20 PM by the_wine_snob
    Upgrading to High Def
    csvideo Level 1
      Upgrading to High Definition
      I am currently using PE4, Windows XP Pro
      I have been using a Canon ZR830 NTSC
      I have been happy with my Videos until I bought a new 46 inch HDTV.  Now I notice that the definition of my videos leaves a lot to be desired.  I plan to get a HD camera soon but in the meantime I can borrow one to use.  I know that I must upgrade my software.
      I have a great bluray player.  I do not have a bluray burner.
      My questions are as follows:
      • Should I get PE 7 or 8
      • Can I open a PE4 project in PE7 or PE8
      • If I do a project with HD media and then burn to a SD DVD, how much better will that be than a project with SD media?
      • When I get a bluray burner, is the procedure still to burn the project to a folder and then burn those files onto the disk?
      • Any recommendations on a bluray burner?  Cameras?
      Thanks for your help.
      Cliff
        • 1. Re: Upgrading to High Def
          the_wine_snob Level 9
          Cliff,
          Welcome to the forum.
          I'll take a crack at a couple of your questions.
          Usually. There can be issues with 3rd party Effects and Transitions, and also with things like Themes, or Instant Movies. Now, you cannot go the other direction, so I would do a Save_As, using a different name, so that you do NOT over-write your PrE 4 Project, once you "convert" it to PrE 7, or 8.
          This can be touchy, though some have had good luck. Many feel that Adobe does not do that good a job of converting HD material to SD. Now, one can burn HD to a DVD-Video, with a much reduced Duration (much less room on a DVD-5, or DVE-9, than on a BD). If you do downsample from HD to SD, you will not likely notice much increase is quality. This ARTICLE addresses converting HD to SD, but it is very heavily oriented towards Adobe PrPro CS4, and not PrE.
          Right now, PrE does not allow Burn to Folder for BD Projects, but only to BD. Should an update for PrE 8 be offered, I do not know if this function will be added.
          I'll let some of the HD experts comment on these, plus your other questions.
          You might also want to post to the Muvipix "Community" (their fora), as a lot of folk there do HD and many also use PrE. You'll see some of the same posters, both here and there, but there are many on Muvipix, who do not post to this forum.
          • 2. Re: Upgrading to High Def
            I also think you're going to run into some problems trying to burn a hi-def BluRay file to a DVD disc. That's just not something you're going to be able to do in Premiere Elements.
            • 3. Re: Upgrading to High Def
              csvideo Level 1
              Well, if I have HI DEF media and I need to make a DVD, what do I do?
              Cliff
              • 4. Re: Upgrading to High Def
                Cliff,
                Here's one METHOD, but it is biased towards PrPro.
                There are some other methods, and I will furnish links, as soon as I find them.
