2 Replies Latest reply on Sep 28, 2007 8:51 PM by scrfix
    Passing Variables to ActionScript CS3 from JavaScript
    scrfix Level 1
      Hello,
      I cannot seem to figure out what I am doing wrong and I need some help . Who better to ask than the experts right?
      I have everything working correctly thus far except for this actionscript. I am using Flash CS3 with ActionScript CS3.
      I have 5 buttons made up in flash.
      I am attempting to do the following tasks
      1. Make buttons with effects in flash - done
      2. Put the correct button in the down position based upon the webpage that the user is on.
      In order to perform this dynamically I apparently have to use 3 different languages, PHP, JavaScript, ActionScript.
      I have been messing with this for a week and cannot figure it out. I have all of the rest of the scripts tested and verified working.
      Here is the link to my test page
      http://www.spectacularstuff.com/php-test/inprogress/php-url-detection.php
      Here is all of my code for testing. (This doesn't include any buttons. This is just merely to test to see if I am passing variables.)
      PHP Code to detect the filename.
      <?php
      function curPageName() {
      return substr($_SERVER["SCRIPT_NAME"],strrpos($_SERVER["SCRIPT_NAME"],"/")+1);
      echo "The current page name detected by PHP is ".curPageName();
      JavaScript Code to pass the variables to Flash
      <script language="javascript" src="swfobject.js">
      var so = new SWFObject("php-url-detection.swf", "php-url-detection", "550", "400", "9", "#FFFFFF");
      so.AddVariable("currentpage","<?php echo curPageName(); ?>")
      </script>
      ActionScript Code to get Variables from JavaScript and display them in flash.
      // Dynamically Create Text Fields
      var tf:TextField = new TextField();
      tf.autoSize = TextFieldAutoSize.LEFT;
      tf.border = false;
      addChild(tf);
      var tf2:TextField = new TextField();
      tf2.autoSize = TextFieldAutoSize.LEFT;
      tf2.border = false;
      addChild(tf2);
      //Create variable to write to page
      var myStr2:String;
      //first attempt at putting the variable onto the page.
      //This LoaderInfo has to be capitlized. An error occurs if not.
      var paramObj:Object = LoaderInfo(this.root.loaderInfo).parameters.currentpage;
      //second attempt at putting the variable onto the page
      var myStr:String = this.root.loaderInfo.parameters.currentpage;
      trace (paramObj);
      trace (myStr);
      if (myStr == null)
      myStr = "Flash is not reading the variables from JavaScript. :(";
      myStr2 = " ";
      else
      myStr2 = "Flash is reading the variables from JavaScript!! :)"
      tf.text = myStr; //Display the URL onto the page
      tf2.text = myStr2 //Display Flash is happy
      [-- End of Code --]
      Please help.
      Thank you in advance.
      Wayne
