1. Re: How to add/create Clock, Timer, Timecode or Countdown
Bill Hunt Jan 24, 2010 9:00 AM (in response to marc.bosch)In PrPro and AfterEffects, there is a TimeCode Effect, that, when applied to a Transparent Video Clip, will do exactly what you want. One could size it and position (fixed Effect>Motion>Scale & Motion>Position), as needed. The version in AfterEffects will also allow one to color and change fonts, as is needed. PrE 4 (my version) does not have the TimeCode Effect, but I do not know about later versions.
There is a plug-in, DVDate (there are actually two, but I am referring to the free Russian one), might be able to add the TimeCode to your footage, but I have never used it, as I have PrPro and AE. You might want to explore DVDate, to see if it works for you.
If it does not, contact me via PM (from your Profile>Personal Messages), and I can get the exact details, such as Duration, approximate size, starting point, etc., and can create a DV-AVI (or similar) of the Transparent Video with the TimeCode Effect added. I can then post that to YouSendIt, for you to download and use. You could then Import that footage, place it on a higher Video Track, size/position as required, and you'd have it.
2. Re: How to add/create Clock, Timer, Timecode or Countdown
marc.bosch Jan 24, 2010 9:09 AM (in response to Bill Hunt)Hi Hunt,
thanks-a-lot for the quick answer.
I am using Premiere Elements 8.0 on a 64-Bit machine and Windows.
I will try this:
http://www.dvdate.ru/en/dvrecdate.html
and let you know about the result.
Regards,
Marc
3. Re: How to add/create Clock, Timer, Timecode or Countdown
Bill Hunt Jan 24, 2010 9:46 AM (in response to marc.bosch)Marc,
I think that it will get you what you want, but have never used it to know for sure. I think that I have the download, but have never installed, 'cause I had other methods to create what I needed, and all in my other programs.
Please let us know if it will do the trick for you. There are also probably tons of "stock" timer footage out on the Internet, and in all sorts of displays. With the popularity of 24, and 48 Hours, I would assume that many have created all sorts of "counters," going both up, and down.
4. Re: How to add/create Clock, Timer, Timecode or Countdown
marc.bosch Jan 29, 2010 8:48 AM (in response to Bill Hunt)Hi all,
here my results.
You can install it.
It shows up in Effects.
But as soon as you've put it in - Premiere Elements 8.0 crashes.
It even shows implemented time in the preview, but as soon as you work with it for more then 2-10 seconds it let's Premiere crash.
Seems like we have to wait for an update from the developer.
Regards,
Marc
5. Re: How to add/create Clock, Timer, Timecode or Countdown
nealeh Jan 29, 2010 9:07 AM (in response to Bill Hunt)the_wine_snob wrote:
There is a plug-in, DVDate (there are actually two, but I am referring to the free Russian one), might be able to add the TimeCode to your footage, but I have never used it, as I have PrPro and AE. You might want to explore DVDate, to see if it works for you.The one at http://www.dvdate.ru/en/dvrecdate.html now has a €19.95 cost. The site does not say what the limitations of the download are.
Cheers,
Neale
Insanity is hereditary, you get it from your children -
6. Re: How to add/create Clock, Timer, Timecode or Countdown
Bill Hunt Jan 29, 2010 10:49 AM (in response to marc.bosch)Marc,
Interesting. Maybe there was a change in the way that PrE 8 works with plug-ins. This happens a lot. Also, are you on a 64-bit OS? That could well be an issue. Many commercial 3rd party plug-ins are having to be completely rewritten, as their older versions do not work in a 64-bit environment.
7. Re: How to add/create Clock, Timer, Timecode or Countdown
Bill Hunt Jan 29, 2010 10:51 AM (in response to nealeh)Neale,
Thank you for the info. It looks like things have changed. The only person that I knew, who had used DVDate, and was on this forum, was ATR. Since I have all that I need in either PrPro, or AE (more control and adjustments), I never looked into either program, the then free one, or the commercial one from another developer.
Now, I know to not tout one as "free."
Appreciated,
8. Re: How to add/create Clock, Timer, Timecode or Countdown
fader5 May 3, 2010 1:10 PM (in response to Bill Hunt)This add in is no longer free!
9. Re: How to add/create Clock, Timer, Timecode or Countdown
Bill Hunt May 3, 2010 1:13 PM (in response to fader5)Remember, there are two different programs with that name. Do check for both. Now, it could well be that both are shareware now. It would not be the first time that a freeware product went shareware. Just be judicious in checking both.
