6 Replies Latest reply on Feb 7, 2018 1:07 AM by maxevent
    arrow keys not working in illustartor
    magritte Level 1
      I am working on Illustrator on Mac 10.5.8 and I use a lot the arrow keys(page up,page down) with combination with shift, but suddenly they stop working,that happens only in illustrator,if i want to use them to scroll on a web page they work fine.
      so i was wondering what happend,and how can i fix that?
      Thanks!!
        • 1. Re: arrow keys not working in illustartor
          Wade_Zimmerman Level 6
          There are several programs that can interfere with the use of the shift key and several other keys, like certain versions of Entourage and Quicken.
          but the arrow keys I do not recall being an issue.
          What you can try is to go to Users/Username/Library/Preferences/Adobe Illustrator (version number) Settings folder and thras that folder first quitting Ilustrator.
          Or if that is not working see if you create a new user account and log into that aaccount and see if the problem still exist if not then there is probably a conflict of somekind you will do best then to do a search on the forum or google for Arrow keys do not work in your version of Illustrator
          youy should always give more information lkike what version of AI or if you have plug ins or installed new fonts or plug ins or other software or updates.
          • 2. Re: arrow keys not working in illustartor
            JanelS5 Level 1
            I just looked in Google for the answer to this too.  I tried to nudge an object and nothing happened.  Well my problem was in Preferences - General - Keyboard Increment had somehow been set to zero.  I put in 1 px and it's back to normal now  :-)
            7 people found this helpful
            • 3. Re: arrow keys not working in illustartor
              leigh annd21117686
              Thank you so much your solution for arrow keys not working did the trick. The apple store meant well and they are usually awesome but misinformed me in one to one saying my computer did not have the capacity to make the arrow keys work. I tried the solutions suggested from several posts including command alt shift at opening of Illustrator to command P + R . None of those solutions worked. Your solution did. Thank you!
              • 4. Re: arrow keys not working in illustartor
                maxevent Level 1
                Hello. I have this same problem since my last update in Illustrator CC. Objects won't move anymore when using my arrow cursors. In my settings, it seems that all is ok, but it won't move. Does anybody know of any other setting i could check? In the other Adobe apps, i don't have this problem. My arrows are working in Indesign & Photshop, just not in illustrator.
                • 5. Re: arrow keys not working in illustartor
                  marcios16835395 Level 1
                  I'm with the same problem
                  • 6. Re: arrow keys not working in illustartor
                    maxevent Level 1
                    For me, it was actually resolved with the latest update, so my illustrator is working fine now
