3 Replies Latest reply on Jan 28, 2010 11:51 AM by oukre87
    Trouble with Sony DCR TRV Camcorder
    oukre87
      I am unable to get Prem Elements 8.0 to recognize my Sony DCR TRV Digital Camcorder. I have tried all
      the workarounds including redownloading the Sony Driver Software, Manual install in PE (but Check Status
      remains offline).  I am using the USB link between the camcorder and computer (computer does not have
      firewire).  I have also rebooted the computer, turned camcorder on and off, and I downloaded the Sony
      driver software with the camera not hooked up.  Any suggestions welcomed.
      Sandy
        • 1. Re: Trouble with Sony DCR TRV Camcorder
          the_wine_snob Level 9
          Sandy,
          You will need to install a FW connection on the computer. The USB connection will never be recognized. FW cards are very inexpensive, and if you have a PCMCIA, or ExpressCard slot, you can use that too.
          • 2. Re: Trouble with Sony DCR TRV Camcorder
            Just checked the specs. for the 250 version of your camera, and it mentions that it has an iLink (IEEE-1394) connection.
            If you do add a card, one consideration might be to look for one that has a controller chip for each IEEE-1394 (FW) socket on it. There are also multi-cards, that offer more USB connections, plus several FW connections. All one needs is a few $, an empty PCI slot, and a screwdriver.
            If you get a single controller chip card (cheaper), do not plug any other FW device in, while doing the Capture, regardless of the number of sockets. Also, do not daisy-chain the camera for Capture. You want it to be the ONLY device on that chip.
            • 3. Re: Trouble with Sony DCR TRV Camcorder
              oukre87 Level 1
              Hunt,
                 Thanks very much for the email and suggestions.  I finally stumbled onto the reality
              that I would have to have FW.
              Regards,
              Sandy
              Date: Sun, 24 Jan 2010 13:57:55 -0700
              To: eparker32@hotmail.com
              Subject: Trouble with Sony DCR TRV Camcorder
