2 Replies Latest reply on Oct 24, 2006 7:57 AM by Newsgroup_User
    I have a simple lingo question, but i can't fix it
    Produze
      hi,
      can anybody show me how this script should look like
      what i need is a script that goes to an other frame when gpunten is 8
      and there is a timer, but the time need to be saved if gpunten is 8, 16 or 24.
      i made it like this, but is doesnt work. someone know how to make that??
      de code:
      property scene, the_time
      if ("gpunten")=8 then goToFrame(70)
      if ("gpunten")=16 then goToFrame(100)
      if ("gpunten")=24 then goToFrame(130)
      if ("gpunten")=8 then put the_time to time1
      if ("gpunten")=16 then put the_time to time2
      if ("gpunten")=24 then put the_time to time3
      time1+time2+time3=put totalscore
      --if ("gpunten")= 8 then goToFrame(22)
      global time1
      global time2
      global time3
      global gpunten
      or does someone know how it can be done an other/simpler way to do this
        • 1. Re: I have a simple lingo question, but i can't fix it
          Level 7
          Quotation marks "" are meant to contain literal strings,
          gpunten = 8
          if (gpunten)=8 then goToFrame(70) -- legal integer variable
          Your assignment syntax is unusual, these examples are more standard
          if (gpunten)=8 then the_time = time1
          if (gpunten)=8 then set the_time = time1
          (the_time would have to be a varible, not to bve confused with the
          system property: the time)
          -- here's how a cse statement might be used
          case of
          8: goToFrame(70)
          16: put the_time to time2
          goToFrame(100)
          24: put the_time to time3
          goToFrame(130)
          end case
          • 2. Re: I have a simple lingo question, but i can't fix it
            Level 7
            I think something like so will do better for you:
            case gpunten of
            8:
            theTime = time1
            go 70
            16:
            theTime = time2
            go 100
            24
            theTime = time3
            go 130
            end case
            Dave -
            Head Developer
            www.blurredistinction.com
            Adobe Community Expert
            http://www.adobe.com/communities/experts/
