8 Replies Latest reply on Sep 5, 2007 2:45 PM by Newsgroup_User
    Random Images as a Background?
    Meowscat Level 1
      Hi. Here I am proud of myself that I figured out how to use an extension and that I made it work. I go the Advanced Random Images created at kaosweaver.com and absolutely love it. However, the way I made this page I need the image to be a background image because I want it to scale and keep the bottom part centered. Does anyone know how I can get random images to load as a background?
      Thanks in advance for any help you can offer.
        • 1. Re: Random Images as a Background?
          Level 7
          On Wed, 5 Sep 2007 00:38:04 +0000 (UTC), "Meowscat"
          > http://saintlukeuniversityparish.org/test.htm page I need the image to be a
          Sure.
          1) Go to hotscripts.com and find a random text script.
          2) Put css for the body in a stylesheet by itself and assign a
          background image.
          3) "Save As" with new name, repeat until you are out of backgrounds.
          4) Call these randomly (in the head, of course).
          • 2. Re: Random Images as a Background?
            FattyLumpkin Level 1
            Hi. Thanks for the quick response. Unfortunately, I have no idea how to do the CSS Stuff. Bleh.
            I did visit that web site. The best I found is the following option. Is this the easiest one? I will have to check on the cgi server stuff. There is no directory for that so I just created one, which leads me to believe that cgi may not be working?
            I'm even willing to approach the page design differently to get the random image thing working because it will end up being important.
            http://www.scriptarchive.com/readme/rand_image.html#how_implement
            • 3. Re: Random Images as a Background?
              Level 7
              On Wed, 5 Sep 2007 02:34:09 +0000 (UTC), "FattyLumpkin"
              >CSS Stuff. Bleh.
              Sure. Open DW, modify CSS for that page only, apply a background, move
              the generated code to a new file and name it with a .css extension.
              Then save as a new file, changing the background image.
              If you get stuck, press F1, use Google or search this group and you
              should be okay in 10 minutes or less.
              >may not be working?
              I have no idea if it's the easiest one, but it may require setting
              permissions (chmod) on the server. Personally, I use PHP.
              Some servers like a .pl extension while others are configured for the
              .cgi extension. I would upload the same file with each extension so
              you can invoke either easily.
              • 4. Re: Random Images as a Background?
                Level 7
                Background images don't scale.
                Murray --- ICQ 71997575
                Adobe Community Expert
                (If you *MUST* email me, don't LAUGH when you do so!)
                http://www.dreamweavermx-templates.com - Template Triage!
                http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
                http://www.dwfaq.com - DW FAQs, Tutorials & Resources
                http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
                "Meowscat" <webforumsuser@macromedia.com> wrote in message
                news:fbktpc$o45$1@forums.macromedia.com...
                > and
                > kaosweaver.com
                > a
                > centered.
                • 5. Re: Random Images as a Background?
                  Level 7
                  First off, thanks for the kind words - second, I wrote an article for
                  Community MX which does exactly what you're asking (although, like
                  Murray said, background images won't scale)
                  http://www.communitymx.com/abstract.cfm?cid=0D745
                  Paul Davis
                  http://www.kaosweaver.com/
                  Visit us for dozens of useful Dreamweaver Extensions.
                  Partner at Community MX - Extend your knowledge
                  • 6. Re: Random Images as a Background?
                    Level 7
                    On Wed, 5 Sep 2007 09:33:15 -0400, "Murray *ACE*"
                    They can with Javascript, but it's not pretty.
                    • 7. Re: Random Images as a Background?
                      Level 7
                      In other words, they don't scale. 8)
                      "Mister Mustard" <mustard@hotdog.com> wrote in message
                      news:k8itd3dlbe27vs0dkesjthglkb5dmnadhg@4ax.com...
                      • 8. Re: Random Images as a Background?
                        Level 7
                        On Wed, 5 Sep 2007 12:08:22 -0400, "Murray *ACE*"
                        Sure they do, just make sure you keep a 4:3 aspect ratio. :)
