10 Replies Latest reply on Jan 27, 2010 11:43 PM by shashank543233
    how to use navigateToUrl for below example..also when i export it its showing a blank page
    shashank543233
      this is the TAG.as file... in the 87th line we have to put the navigatetourl command, i highlighted the lined to be edited
      package
          import flash.display.Sprite;
          import flash.events.MouseEvent;
          import flash.text.TextField;
          import flash.text.TextFieldAutoSize;
          import flash.text.TextFormat;
          import mx.events.MenuEvent;
                  import mx.controls.Alert;
                  import mx.collections.*;
          public class Tag extends Sprite {
              private var _back:Sprite;
              private var _node:Object;
              private var _cx:Number;
              private var _cy:Number;
              private var _cz:Number;
              private var _color:Number;
              private var _hicolor:Number;
              private var _active:Boolean;
              private var _tf:TextField;
              private var keyword:String;
              //You need to embed a font
              [Embed(systemFont="Tahoma",
                          fontName="myFont",
                          mimeType="application/x-font")]
              public var myFont:Class;
              public function Tag( node:Object, color:Number, hicolor:Number ){
                  _node = node;
                  keyword = node.name;
                  _color = color;
                  _hicolor = hicolor;
                  _active = false;
                  // create the text field
                  _tf = new TextField();
                  _tf.autoSize = TextFieldAutoSize.LEFT;
                  _tf.selectable = false;
                  // set styles
                  var format:TextFormat = new TextFormat();
                  format.font = "myFont";
                  format.bold = true;
                  format.color = color;
                  format.size = ((8*node.size)/50);
                  _tf.defaultTextFormat = format;
                  _tf.embedFonts = true;
                  // set text
                  _tf.text = node.name;
                  addChild(_tf);
                  // scale and add
                  _tf.x = -this.width / 2;
                  _tf.y = -this.height / 2;
                  // create the back
                  _back = new Sprite();
                  _back.graphics.beginFill( _hicolor, .4 );
                  _back.graphics.lineStyle( 0, _hicolor );
                  _back.graphics.drawRect( 0, 0, _tf.textWidth+20, _tf.textHeight+5 );
                  _back.graphics.endFill();
                  addChildAt( _back, 0 );
                  _back.x = -( _tf.textWidth/2 ) - 10;
                  _back.y = -( _tf.textHeight/2 ) - 2;
                  _back.visible = false;
                  // force mouse cursor on rollover
                  this.mouseChildren = false;
                  this.buttonMode = true;
                  this.useHandCursor = true;
                  // events
                  this.addEventListener(MouseEvent.MOUSE_OUT, mouseOutHandler);
                  this.addEventListener(MouseEvent.MOUSE_OVER, mouseOverHandler);
                  this.addEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
              private function mouseOverHandler( e:MouseEvent ):void {
                  _back.visible = true;
                  _tf.textColor = _hicolor;
                  _active = true;
              private function mouseOutHandler( e:MouseEvent ):void {
                  _tf.textColor = _color;
                  _active = false;
             private function mouseUpHandler( e:MouseEvent ):void {
                  var objURLReq:URLRequest = new URLRequest(event.item.@data.toString());
                 navigateToURL(objURLReq, "_self");
              // setters and getters
              public function set cx( n:Number ):void{ _cx = n }
              public function get cx():Number { return _cx; }
              public function set cy( n:Number ):void{ _cy = n }
              public function get cy():Number { return _cy; }
              public function set cz( n:Number ):void{ _cz = n }
              public function get cz():Number { return _cz; }
              public function get active():Boolean { return _active; }
      and this is the xml file related..
      <?xml version="1.0" encoding="UTF-8"?>
      <tags>
        <tag>
          <name>Illustration</name>
          <data>"http://www.adobe.com/"</data>
          <tid>2</tid>
          <weight>1</weight>
          <counter>4</counter>
          <repetead>2</repetead>
          <size>133.33333333333</size>
          <meuPeso>6</meuPeso>
        </tag>
        <tag>
          <name>CorelDraw</name>
          <tid>113</tid>
          <weight>1</weight>
          <counter>3</counter>
          <repetead>0</repetead>
          <size>113.33333333333</size>
          <meuPeso>3</meuPeso>
        </tag>
        <tag>
          <name>Design</name>
          <tid>1</tid>
          <weight>1</weight>
          <size>126.66666666667</size>
          <meuPeso>5</meuPeso>
        </tag>
        <tag>
          <name>Flex</name>
          <tid>6</tid>
          <weight>1</weight>
          <repetead>4</repetead>
          <size>140</size>
          <meuPeso>7</meuPeso>
        </tag>
        <tag>
          <name>mxml</name>
          <tid>15</tid>
          <weight>1</weight>
          <counter>2</counter>
          <size>120</size>
          <meuPeso>4</meuPeso>
        </tag>
        <tag>
          <name>skin</name>
          <tid>14</tid>
          <weight>1</weight>
          <size>106.66666666667</size>
          <meuPeso>2</meuPeso>
        </tag>
        <tag>
          <name>Eclipse</name>
          <tid>12</tid>
          <weight>1</weight>
          <size>120</size>
        </tag>
        <tag>
          <name>swf</name>
          <tid>9</tid>
          <weight>1</weight>
        </tag>
        <tag>
          <name>Flash</name>
          <tid>8</tid>
          <weight>1</weight>
          <size>120</size>
        </tag>
        <tag>
          <name>Tour de Flex</name>
          <tid>13</tid>
          <weight>1</weight>
          <size>120</size>
        </tag>
        <tag>
          <name>Flex Builder</name>
          <tid>11</tid>
          <weight>1</weight>
          <size>120</size>
        </tag>
        <tag>
          <name>ActionScript</name>
          <tid>10</tid>
          <weight>1</weight>
          <size>120</size>
        </tag>
        <tag>
          <name>Adobe</name>
          <tid>7</tid>
          <weight>1</weight>
          <size>120</size>
        </tag>
        <tag>
          <name>as</name>
          <tid>17</tid>
          <weight>1</weight>
          <repetead>10</repetead>
          <size>173.33333333333</size>
          <meuPeso>12</meuPeso>
        </tag>
        <tag>
          <name>as3</name>
          <tid>16</tid>
          <weight>1</weight>
          <size>120</size>
        </tag>
        <tag>
          <name>Cinema 4D</name>
          <tid>4</tid>
          <weight>1</weight>
          <counter>1</counter>
          <size>100</size>
          <meuPeso>1</meuPeso>
        </tag>
        <tag>
          <name>Pencil</name>
          <tid>126</tid>
          <weight>1</weight>
          <repetead>1</repetead>
        </tag>
        <tag>
          <name>Collage</name>
          <tid>112</tid>
          <weight>1</weight>
          <size>100</size>
        </tag>
        <tag>
          <name>Colors</name>
          <tid>127</tid>
          <weight>1</weight>
          <size>100</size>
        </tag>
        <tag>
          <name>Graphic</name>
          <tid>109</tid>
          <weight>1</weight>
          <size>100</size>
        </tag>
        <tag>
          <name>Photoshop</name>
          <tid>18</tid>
          <weight>1</weight>
        </tag>
        <tag>
          <name>Course</name>
          <tid>125</tid>
          <weight>1</weight>
          <repetead>3</repetead>
          <size>120</size>
        </tag>
        <tag>
          <name>PHP</name>
          <tid>110</tid>
          <weight>1</weight>
          <size>120</size>
        </tag>
        <tag>
          <name>Reference</name>
          <tid>5</tid>
          <weight>1</weight>
        </tag>
        <tag>
          <name>Web Design</name>
          <tid>3</tid>
          <weight>1</weight>
          <size>100</size>
        </tag>
        <tag>
          <name>Yoga</name>
          <tid>111</tid>
          <weight>1</weight>
        </tag>
        <tag>
          <name>Collection</name>
          <tid>120</tid>
          <weight>1</weight>
        </tag>
        <tag>
          <name>Card</name>
          <tid>108</tid>
          <weight>1</weight>
          <size>100</size>
        </tag>
        <tag>
          <name>Carvalhar.com</name>
          <tid>124</tid>
          <weight>2</weight>
        </tag>
      </tags>
      it also has 2 other files, it will be required to meet my requirements
        • 1. Re: how to use navigateToUrl for below example..also when i export it its showing a blank page
          archemedia Level 4
          What does this return? I can only find one data tag in you xml (the first node).
          Dany
          • 2. Re: how to use navigateToUrl for below example..also when i export it its showing a blank page
            shashank543233 Level 1
            i already did convert that to a string.. and i am getting some errors..call to undefined urlrequest ...
              And i figured out that first i will deal with one node and then generalize it
            • 3. Re: how to use navigateToUrl for below example..also when i export it its showing a blank page
              seRajan
              hi,
                   Please check the "event" and "item".
              from this function argument is "e", but your are handling "event". another thing is "item" not in MouseEvent property. Xml Load functions not avail in this code.
              - Rajan
              • 4. Re: how to use navigateToUrl for below example..also when i export it its showing a blank page
                yes, i have taken care of event but could u tell what to do with item...i am new to coding and i am finding it difficult to correct...would be great if u elaborate
                • 5. Re: how to use navigateToUrl for below example..also when i export it its showing a blank page
                  archemedia Level 4
                  Can you debug your application and put a breakpoint in your function. Then post an image of the event object (e)?
                  What is causing the event? Is it a datagrid?
                  Dany
                  • 6. Re: how to use navigateToUrl for below example..also when i export it its showing a blank page
                    no ,its not a data grid... actually its a tag cloud...xml files are used to name them and i have a file name tagcloud.as where all the stuff is there..i will paste that....
                    package
                        import flash.events.Event;
                        import flash.net.URLLoader;
                        import mx.containers.Canvas;
                        import mx.core.UIComponent;
                        import mx.rpc.events.ResultEvent;
                        import mx.rpc.http.HTTPService;
                        public class TagCloud extends Canvas    {
                            private var radius:Number;
                            private var mcList:Array;
                            private var dtr:Number;
                            private var d:Number;
                            private var sa:Number;
                            private var ca:Number;
                            private var sb:Number;
                            private var cb:Number;
                            private var sc:Number;
                            private var cc:Number;
                            private var originx:Number;
                            private var originy:Number;
                            private var tcolor:Number;
                            private var hicolor:Number;
                            private var tcolor2:Number;
                            private var tspeed:Number;
                            private var distr:Boolean;
                            private var lasta:Number;
                            private var lastb:Number;
                            private var holder:UIComponent;
                            private var active:Boolean;
                            private var myXML:XML;
                            private var myLoader:URLLoader;
                            private var widthTag:Number;
                            private var heightTag:Number;
                            //this number changes if it's elliptical or spherical
                            [Bindable]
                            public var howElliptical:Number=1;
                            public function TagCloud(){
                                goTagGo();
                            public function goTagGo():void {
                                tspeed = 1;
                                distr = true; //distribute the words or not
                                // load XML file
                                var service : HTTPService = new HTTPService();
                                //the url for the tag xml...
                                  service.url = 'tagcloud.xml';
                                   service.addEventListener(ResultEvent.RESULT, xmlLoaded);
                                  service.send();
                            private function xmlLoaded(e:Event):void {
                                trace("xml loaded");
                                //define sizes
                                widthTag = this.width - this.width/10;
                                heightTag = this.height - this.height/10;
                                //load the xml info using E4X
                                var result:* = HTTPService(e.target).lastResult;
                                if(result.tags){
                                    // set some vars
                                    radius = 150;
                                    dtr = Math.PI/180;
                                    d=300;
                                    sineCosine( 0,0,0 );
                                    mcList = [];
                                    active = false;
                                    lasta = 1;
                                    lastb = 1;
                                    // create holder mc, center it
                                    holder = new UIComponent();
                                    addChild(holder);
                                    resizeHolder();
                                    // loop though them to find the smallest and largest 'tags'
                                    var largest:Number = 0;
                                    var smallest:Number = 9999;
                                        for each (var tag:Object in result.tags.tag )  {
                                            largest = Math.max( largest, tag.meuPeso );
                                            smallest = Math.min( smallest, tag.meuPeso );
                                            // create movie clips
                                            var perc:Number = ( smallest == largest ) ? 1 : (tag.meuPeso-smallest) / (largest-smallest);
                                            var col:Number = 0x000000;
                                            var hicol:Number = 0xFFEF07;
                                            var mc:Tag = new Tag( tag, col, hicol );
                                            holder.addChild(mc);
                                            holder.x = (this.widthTag/2) - (holder.width/2);
                                            holder.y = (this.heightTag/2) - (holder.height/2);
                                            // store reference
                                            mcList.push( mc );
                                        // distribute the tags on the sphere
                                        positionAll();
                                        // add event listeners
                                        this.addEventListener(Event.ENTER_FRAME, updateTags);
                                        parent.addEventListener(MouseEvent.ROLL_OUT, mouseExitHandler);
                                        parent.addEventListener(MouseEvent.MOUSE_MOVE, mouseMoveHandler);
                                        this.addEventListener(Event.RESIZE, resizeHandler);
                            private function updateTags( e:Event ):void {
                                var a:Number;
                                var b:Number;
                                if( active ){
                                    a = (-Math.min( Math.max( holder.mouseY, -250 ), 250 ) / 150 ) * tspeed;
                                    b = (Math.min( Math.max( holder.mouseX, -250 ), 250 ) /150 ) * tspeed;
                                } else {
                                    a = lasta * 0.98;
                                    b = lastb * 0.98;
                                lasta = a;
                                lastb = b;
                                // if a and b under threshold, skip motion calculations to free up the processor
                                if( Math.abs(a) > 0.01 || Math.abs(b) > 0.01 ){
                                    var c:Number = 0;
                                    sineCosine( a, b, c );
                                    // bewegen van de punten
                                    for( var j:Number=0; j<mcList.length; j++ ) {
                                        // multiply positions by a x-rotation matrix
                                        var rx1:Number = mcList[j].cx;
                                        var ry1:Number = mcList[j].cy * ca + mcList[j].cz * -sa;
                                        var rz1:Number = mcList[j].cy * sa + mcList[j].cz * ca;
                                        // multiply new positions by a y-rotation matrix
                                        var rx2:Number = rx1 * cb + rz1 * sb;
                                        var ry2:Number = ry1;
                                        var rz2:Number = rx1 * -sb + rz1 * cb;
                                        // multiply new positions by a z-rotation matrix
                                        var rx3:Number = rx2 * cc + ry2 * -sc;
                                        var ry3:Number = rx2 * sc + ry2 * cc;
                                        var rz3:Number = rz2;
                                        // set arrays to new positions
                                        mcList[j].cx = rx3;
                                        mcList[j].cy = ry3;
                                        mcList[j].cz = rz3;
                                        // add perspective
                                        var per:Number = d / (d+rz3);
                                        // setmc position, scale, alpha
                                        mcList[j].x = (howElliptical * rx3 * per) - (howElliptical*2); //original is mcList[j].x = rx3 * per;
                                        mcList[j].y = ry3 * per;
                                        mcList[j].scaleX = mcList[j].scaleY =  per;
                                        mcList[j].alpha = per/2;
                                    depthSort();
                            private function depthSort():void {
                                mcList.sortOn( "cz", Array.DESCENDING | Array.NUMERIC );
                                var current:Number = 0;
                                for( var i:Number=0; i<mcList.length; i++ ){
                                    holder.setChildIndex( mcList[i], i );
                                    if( mcList[i].active == true ){
                                        current = i;
                                holder.setChildIndex( mcList[current], mcList.length-1 );
                            /* See http://blog.massivecube.com/?p=9 */
                            private function positionAll():void {
                                var phi:Number = 0;
                                var theta:Number = 0;
                                var max:Number = mcList.length;
                                // mix up the list so not all a' live on the north pole
                                mcList.sort( function():Number{ return Math.random()<0.5 ? 1 : -1; } );
                                // distibute
                                for( var i:Number=1; i<max+1; i++){
                                    if( distr ){
                                        phi = Math.acos(-1+(2*i-1)/max);
                                        theta = Math.sqrt(max*Math.PI)*phi;
                                    }else{
                                        phi = Math.random()*(Math.PI);
                                        theta = Math.random()*(2*Math.PI);
                                    // Coordinate conversion
                                    mcList[i-1].cx = radius * Math.cos(theta)*Math.sin(phi);
                                    mcList[i-1].cy = radius * Math.sin(theta)*Math.sin(phi);
                                    mcList[i-1].cz = radius * Math.cos(phi);
                            private function mouseExitHandler( e:Event ):void {
                                 active = false;
                                // trace("mouseExitHandler, active: " + active);
                            private function mouseMoveHandler( e:MouseEvent ):void {
                                active = true;
                                //trace("mouseMoveHandler, active: " + active);
                            private function resizeHandler( e:Event ):void { resizeHolder(); }
                            private function resizeHolder():void {
                                holder.x = (this.width/2) - (holder.width/2);
                                holder.y = (this.height/2) - (holder.height/2);
                                var scale:Number;
                                if( width > height ){
                                    scale = (height/500);
                                } else {
                                    scale = (width/500);
                                holder.scaleX = holder.scaleY = scale;
                            private function sineCosine( a:Number, b:Number, c:Number ):void {
                                sa = Math.sin(a * dtr);
                                ca = Math.cos(a * dtr);
                                sb = Math.sin(b * dtr);
                                cb = Math.cos(b * dtr);
                                sc = Math.sin(c * dtr);
                                cc = Math.cos(c * dtr);
                            private function getColorFromGradient( perc:Number ):Number {
                                var r:Number = ( perc * ( tcolor >> 16 ) ) + ( (1-perc) * ( tcolor2 >> 16 ) );
                                var g:Number = ( perc * ( (tcolor >> 8) % 256 ) ) + ( (1-perc) * ( (tcolor2 >> 8) % 256 ) );
                                var b:Number = ( perc * ( tcolor % 256 ) ) + ( (1-perc) * ( tcolor2 % 256 ) );
                                return( (r << 16) | (g << 8) | b );
                    • 7. Re: how to use navigateToUrl for below example..also when i export it its showing a blank page
                      seRajan Level 1
                      hi,     I don't unterstand the flow, Could yousend the your package?- Rajan
                      • 9. Re: how to use navigateToUrl for below example..also when i export it its showing a blank page
                        seRajan Level 1
                        hi,
                        I attached updated source file. Please check and give the commants.
                        I updated the XML file, added the data node for url like.
                        MouseUp handler updated in Tag.as file.
                        - Rajan
                        • 10. Re: how to use navigateToUrl for below example..also when i export it its showing a blank page
                          thanks man!!!! that code worked like a charm:)...but still i face a small problem...when i export , i get a internal build error and and when i ignore that and export i cant view the output in either swf or html file
