0 Replies Latest reply on Jan 24, 2010 11:30 PM by gr8momo
    unloading shared library
    gr8momo
      Hello all,
      Im using a shared library in my application (Export/Import for runtime sharing).
      This is how my application is structured (simple test application):
      I have a main.swf which loads view.swf which uses a asset from a shared library asset.swf.
      The application loads up fine and I see the shared asset. On a key press i unload the view.swf. The unload works fine as well.
      I then replace the view.swf and asset.swf with a different view and asset.
      On another key press I load the view.swf again.
      Result: I see the updated view but the asset is still the old one
      From this I can deduce that even though the view.swf was unloaded the main still holds the refernce to asset.swf.
      My question: is there a way to ensure the shared library is freed?
      Any thoughts on this behaviour?
      Thanks guys.
      Environment: Flash Player 8 and ActionScript 2.0
      (p.s: i can post my fls's/swf's if the question is not that clear. )
