1 Reply Latest reply on Jan 25, 2010 9:46 AM by bringrags
    Problems with stop AudioElement added in SerialElement
    ZAGU
      Hi.
      I am using OSMF Sprint 8 Release.
      Problem is that. If you add AudioElement into SerialElement for playing one and then try calling stop() method then playback stops but currentTime property (MediaPlayer property) doesn't jump to 0 sec. Then if you try call play() method (restart) then playing begins but CURRENT_TIME_CHANGE event doesn't fire. Also if play this SerialElement and wait for one stop then audio stops playing but currentTime property doesn't jump to 0 sec and if restart playing CURRENT_TIME_CHANGE event doesn't fire.
      As opposite behavior is that if play AudioElement wihout adding one into SerialElementall all working good in all cases: currentTime jump to 0 sec and CURRENT_TIME_CHANGE event fires always.
      Is it bug ? Please check.
      Please look at code below and in attached Main.as.
      package
          public class Main extends Sprite
              public function Main()
                  var mediaPlayerSprite:MediaPlayerSprite = new MediaPlayerSprite();
                  addChild(mediaPlayerSprite);
                  mediaPlayer = mediaPlayerSprite.mediaPlayer;
                  mediaPlayer.addEventListener(TimeEvent.CURRENT_TIME_CHANGE, onCurrentTimeChange);
                  mediaPlayer.addEventListener(PlayEvent.PLAY_STATE_CHANGE, onPlayStateChange);
                  //mediaPlayerSprite.element = serialMedia;
                  mediaPlayerSprite.element = audioElement;
              private function onPlayClick(event : MouseEvent) : void
                  mediaPlayer.play();
              private function onStopClick(event : MouseEvent) : void
                  mediaPlayer.stop();
              public function get audioElement() : AudioElement
                  var AUDIO_URL : String = 'tin.mp3';
                  var audioLoader: SoundLoader = new SoundLoader();
                    var audio : AudioElement = new AudioElement( audioLoader,new URLResource(new URL(AUDIO_URL)));
                    return audio;
              public function get serialMedia() : SerialElement
                  var serialMedia : SerialElement = new SerialElement();
                  serialMedia.addChild(audioElement);
                  return serialMedia;
              private function onCurrentTimeChange(event : TimeEvent) : void
                  trace(mediaPlayer.currentTime,mediaPlayer.duration);
              private function onPlayStateChange(event : PlayEvent) : void
                  trace(event.playState);
      Thank you in advance
      Alexandr.
