1 Reply Latest reply on Jan 26, 2010 9:12 AM by Linda Nicholls
    Saving Files State Naming.
    Chris Goodiel
      Is there a way to change the default naming of states when saving images over states. Currently the default for state 2 for instance would be "_f2"( which I think is interesting that it was not changed to "_s2" considering they are no longer "frames").
      Anyways I primarily would use fireworks and states for that matter to create button not exporting html. State 2 would typically be my over state of a button i just don't want to have to go in and manually change all of the file names after the fact.
      Thanks for your time,
      Chris
        • 1. Re: Saving Files State Naming.
          Linda Nicholls Level 4
          You can change that under File > HTML Setup. Click on the Document Specific tab.  Note the way I have set up the preferences in the attached image. The button states will export as button3up, button3over, etc. Click the Set Defaults button to use your new settings for all future documents. This works whether you are exporting images and HTML, or just images.
