3 Replies Latest reply on Jan 25, 2010 6:51 AM by edwinmerced
    Making it more efficient
    edwinmerced Level 1
      I will be using this function
                     private function inter_1a(evt:MouseEvent):void {
                      var popUpInterDisplay:interactionexporter;
                      popUpInterDisplay = new interactionexporter();
                      popUpInterDisplay.source = "lessons/lessonone/interactions/inter1a.swf";
                      PopUpManager.addPopUp(popUpInterDisplay, this, true);
      But will use it at least 30 times. For example:
                     private function inter_1b(evt:MouseEvent):void {
                      popUpInterDisplay.source = "lessons/lessonone/interactions/inter1b.swf";
                 private function inter_1c(evt:MouseEvent):void {
                       popUpInterDisplay.source = "lessons/lessonone/interactions/inter1c.swf";
          ETC......
      Any ideas as to make this more efficient?
        • 1. Re: Making it more efficient
          archemedia Level 4
          This can be written more efficient indeed. How are these functions called, by Buttons or by an item in a datagrid?
          In case it are buttons, you can store the name of the swf in their id properties:
          private function inter(evt:MouseEvent):void
                var popUpInterDisplay:interactionexporter = new interactionexporter();
                popUpInterDisplay.source = "lessons/lessonone/interactions/" + evt.target.id + ".swf";
          In case of a datagrid, you can use a property of the selectedItem:
                 popUpInterDisplay.source = "lessons/lessonone/interactions/" + evt.currentTarget.selectedItem.propName + ".swf";
          Dany
          • 2. Re: Making it more efficient
            edwinmerced Level 1
            Dany Thank you Very Much!!! I used the button version.
            • 3. Re: Making it more efficient
              edwinmerced Level 1
              Thanks to the participnts nd to the forum organizers for providing this learning space!
