2 Replies Latest reply on Jan 27, 2010 3:49 AM by FlexMitchell
    why can't disable print dialog?
    FlexMitchell
      I need print document to xxx.ps
      My codes are : ( delphi code)
      bsInDoc.PrintPreferences.ActivePrinterPreset := PStyle;
      bsInDoc.PrintPreferences.PrintFile :=  'C:\pstest.ps';
      bsInDoc.PrintOut(False,PStyle,False);
      While running this code, Indesign CS4 still raise a small dialog: ask fileName.
      Print.out method has 3 Parameters:
      PrintDialog: Whether to invoke the print dialog. Type: Boolean.
      Using: Printer preset to use. Type: idPrinterPresetTypes enumerator or PrinterPreset.
      WithGrids: Whether to print grids
      so, I set first parameter = False, the printdialog should not be invoked by Indesign CS4.
      But it does not, why?(refer to the figure as below)
      Anyone has idea about it?
      P.S: this Indesign CS4 is Chinese version. and there are two black form is my delphi program.
        • 1. Re: why can't disable print dialog?
          The function suppresses InDesign's own Print dialog, not the one your system calls up.
          I think you get one from the system because you are printing to a file using your printer driver, rather than print to PostScript from InDesign.
          • 2. Re: why can't disable print dialog?
            FlexMitchell Level 1
            Finally, I solve this problem.
            The answer is so easy ,
            PrintOut(False).
            Just fill first first parameter, do not care the other two parameter.
            According to Indesign CS4 scripting document, it points out one thing is strange. Document says  InDesign.PrinterPreset.PrintFile :  The PostScript file to print to. Note: Valid only when the current printer is defined as postscript file. Then, I test setup PreinterPreset with postscript option or not, the result is same , Indesign will print document to .ps file. and I notice there is another method InDesign.PrintPreference.PrintFile has same definition. But, I do not figure out what is the difference between them.
            Actually speaking, I hope adobe script document can apply more examples to help user to understand it.
            Scripting can do a lot of smart things and saving manpower, what not let more user has scripting ability.
            P.S:  thanks a lot for Jonqware answer, your clue guide me to find correct answer.
