1 Reply Latest reply on Jan 27, 2010 9:20 AM by rexdtripod
    How can NetStream bufferLength property contain wrong values?  Desparate, please respond.
    rexdtripod Level 1
      I can't believe I can't get no love on this.  Maybe my other post is too long and unfocused and people are just passing it by.  Could someone from Adobe please respond to this?  It seems like a pretty bad bug.
      When buffering up to 20 seconds on a live NetStream, I check the bufferLength property every second with an interval.  The numbers 37.95 - 46.794 below are WRONG.  They are BOGUS DATA.  They cause ridiculous rapid fire cycles of buffering and rebuffering.  Playback is ruined.  This happens on various machines and browsers.  It also happens if I change encoding locations, encoding devices, and CDN's.  My testing on it has been exhaustive.
      The NetStatusEvent code property "NetStream.Buffer.Full" is thrown even though it is not really full.  The player then plays too soon - before the buffer if full.
      Please help.
      Buffer empty:
      0.423
      0.919
      1.768
      2.591
      3.374
      4.21
      5.151
      5.987
      Buffer full:
      37.95
      47.596
      47.346
      47.251
      46.922
      46.731
      46.794
      5.374
      5.098
      4.429
      3.95
      3.334
        • 1. Re: How can NetStream bufferLength property contain wrong values?  Desparate, please respond.
          rexdtripod Level 1
          Give it a shot yourself.  Here is the simplest of live streaming video players.  No frills.  Just connect it to your live stream by changing the defaultURL string and stream name in the ns.play() statement.
          Run it in Flex debug mode.  It will check and print the ns.bufferLength property every second.  The buffer is set to 20 secs currently.  Last time I ran it, I never made it above 2 seconds in the buffer.  Player started playing right away instead of buffering the full 20 secs first.
          Can you not buffer a live stream reliably or is there something wrong with the code?
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
              initialize="init()">
              <mx:Script>
                  <![CDATA[
                      import flash.media.Video;
                      import flash.net.NetConnection;
                      import flash.net.NetStream;
                      import mx.core.UIComponent;
                      private var vid:Video;
                      private var videoHolder:UIComponent;
                      private var nc:NetConnection;
                      private var defaultURL:String="rtmp://your_streaming_server";
                      private var ns:NetStream;
                      private var msg:Boolean;
                      private var intervalMonitorBufferLengthEverySecond:uint;
                      private function init():void
                          vid=new Video();
                          vid.width=864;
                          vid.height=576;
                          vid.smoothing = true;
                          //Attach the video to the stage
                          videoHolder = new UIComponent();
                          videoHolder.addChild(vid);
                          addEventListener(SecurityErrorEvent.SECURITY_ERROR, onSecurityError);
                          this.addChild(videoHolder);
                          connect();
                      public function onSecurityError(e:SecurityError):void
                          trace("Security error: ");
                      public function connect():void
                          nc = new NetConnection();
                          nc.client = this;
                          nc.addEventListener(NetStatusEvent.NET_STATUS, netStatusHandler);
                          nc.connect(defaultURL, false);
                      public function netStatusHandler(e:NetStatusEvent):void
                            switch (e.info.code) {
                              case "NetConnection.Connect.Success":
                                  trace("Connected successfully");
                                  createNS();
                                  break;
                               case "NetConnection.Connect.Closed":
                                  trace("Connection closed");
                                  connect();
                                  break;
                              case "NetConnection.Connect.Failed":
                                  trace("Connection failed");
                                  break;
                              case "NetConnection.Connect.Rejected":
                                  trace("Connection rejected");
                                  break;
                              case "NetConnection.Connect.AppShutdown":
                                  trace("App shutdown");
                                  break;
                              case "NetConnection.Connect.InvalidApp":
                                  trace("Connection invalid app");
                                  break;
                      public function createNS():void
                          trace("Creating NetStream");
                           ns=new NetStream(nc);
                           //nc.call("FCSubscribe", null, "your_stream_name");//Use this only if your CDN requires it
                           ns.addEventListener(NetStatusEvent.NET_STATUS, netStreamStatusHandler);
                          vid.attachNetStream(ns);
                          //Handle onMetaData and onCuePoint event callbacks: solution at http://tinyurl.com/mkadas
                          //See another solution at http://www.adobe.com/devnet/flash/quickstart/metadata_cue_points/
                          var infoClient:Object = new Object();
                          infoClient.onMetaData = function oMD():void {};
                          infoClient.onCuePoint = function oCP():void {};
                          ns.client = infoClient;
                          ns.bufferTime = 20;
                          ns.play("your_stream_name");
                          ns.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler);
                          function asyncErrorHandler(event:AsyncErrorEvent):void {
                              trace(event.text);
                          intervalMonitorBufferLengthEverySecond = setInterval(monPlayback, 1000);
                      public function netStreamStatusHandler(e:NetStatusEvent):void
                              case "NetStream.Buffer.Empty":
                                  trace("Buffer empty: ");
                                  break;
                              case "NetStream.Buffer.Full":
                                  trace("Buffer full:");
                                  break;
                               case "NetStream.Play.Start":
                                  trace("Play start:");
                                  break;
                      public function monPlayback():void {
                          // Print out current buffer length
                          trace("Buffer length: " + ns.bufferLength);
                      public function onBWDone():void {
                          //Do nothing
                      public function onFCSubscribe(info:Object):void {
                      // Do nothing. Prevents error with CDN's.
                      public function onFCUnsubscribe(info:Object):void {
              </mx:Script>
          </mx:Application>
          My last run:
          Creating NetStream
          Play start:
          Buffer length: 0.001
          Buffer full:  //Obviously the buffer is not full here.  Bogus.
          Buffer length: 2.202
          Buffer length: 2.369
          Buffer length: 2.102
          Buffer length: 2.402
          Buffer length: 2.302
          Buffer length: 2.269
          Buffer length: 1.926
          Buffer length: 2.336
          Buffer length: 2.286
          Buffer length: 2.403
          Buffer length: 2.388
          Buffer length: 2.335
          Buffer length: 2.339
          Buffer length: 2.396
          Buffer length: 2.436
