11 Replies Latest reply on Feb 1, 2010 3:05 PM by Flex harUI
    Displaying Row Number in DataGrid
    olegkon Level 1
      Is there an easy way to display a Row Number (in the very first column) in DataGrid or AdvancedDataGrid ?
      I am trying to emulate Excel kind of functionality in DataGrid,
      so need to Open/Load & Save to file.
      I do understand that it is not difficult to do,
      but do not want to Load & Save these Row Numbers to file.
      Is there any easy standard solution for that ?
      Any code samples ?
      TIA,
      Oleg.
        • 1. Re: Displaying Row Number in DataGrid
          Matt Le Fevre Level 4
          datagrid row number is fairly straightforward, or so google has led me to believe
          http://www.cflex.net/showFileDetails.cfm?ObjectID=735
          • 2. Re: Displaying Row Number in DataGrid
            olegkon Level 1
            Grizzz,
            Maybe I didn't express that enough.
            I mean, is there any feature in DataGrid (or maybe in AdvancedDG)
            which lets you make RowNumber column external ro data ArrayCollection,
            part of the GUI rather than part of Data ?
            (so I don't need to Load/Save it in Excel file)
            Oleg.
            • 3. Re: Displaying Row Number in DataGrid
              Flex harUI Adobe Employee
              If you don't have a lot of rows, you can use labelFunction on a column that
              calls getItemIndex on the data.  It does a linear search which is why it
              will slow you down if you have a lot of rows.
              If you have a lot of rows, you might try a custom renderer that displays the
              value of listData.rowIndex + dataGrid.verticalScrollPosition.
              • 4. Re: Displaying Row Number in DataGrid
                olegkon Level 1
                I like that labelFunction, tried to use it with DataGrid.
                It worked fine in one case (when I initialize the DataGrid), returning me correct row numbers.
                But in another case (where I load the data from the file (as XMLListCollection) into the dataGrid:
                I loop through the DG columns, and for column=0 do:
                dgc.labelFunction = lfRowNum;
                then:  columns.push(dgc);
                dg.dataProvider = myXMLListCollection;
                So in this case I do not loop through rows of the collection.
                And then I see the value 0 as row number for all rows.
                Is there some trick to the labelFunction ?
                TIA,
                Oleg.
                • 5. Re: Displaying Row Number in DataGrid
                  No real tricks to labelfunction.  But you can't just push a column. You have
                  to modify the array and reassign the columns property.
                  • 6. Re: Displaying Row Number in DataGrid
                    olegkon Level 1
                    I guess, that labelFunction is a callback function.
                    It is getting called, but in all rows it's equal 0.
                    > You have to modify the array and reassign the columns property.
                    I do not need to modify that ArrayCollection (maybe add a blank string to its elements?),
                    and I am assigning it to the DataGrid.dataProvider.
                    Is that sufficient ?
                    • 7. Re: Displaying Row Number in DataGrid
                      Are you getting a column of zeros?  If so, then you added the column
                      correctly.  Maybe show us what you are using for a labelFunction.
                      • 8. Re: Displaying Row Number in DataGrid
                        olegkon Level 1
                        Yes, I am getting column with all "0".
                        I took labelFunction from the link in one of the previous posts as-is:
                        // labelFunction for Row Number of the DataGrid
                        private function lfRowNum(oItem:Object, iCol:int):String {
                        var iIndex:int = gridData.getItemIndex(oItem) + 1;
                        Alert.show(
                        "lfRowNum() i="+iCol+", rowNum="+String(iIndex)+", item='"+oItem.toString()+"'");
                        return String(iIndex);
                        grid.dataProvider = null; // reset
                        var dgc:DataGridColumn;
                        var aColumnsNew:Array = new Array();
                        for (var i:int=0; i <= aColumnDef.length; i++) { //loop over the column definition array (& add 0-th column - row num)
                        dgc = new DataGridColumn(); //instantiate a new DataGridColumn
                        if (i > 0) {
                        oColumnDef = aColumnDef[i-1];
                        dgc.dataField = oColumnDef.dataField;
                        else { //  add 0-th column (row num)
                        dgc.dataField = "";
                        aColumnsNew.push(dgc);
                        Sorry, I could not format that code ptoperly, would not let me remove spaces and blank lines.
                        • 9. Re: Displaying Row Number in DataGrid
                          I'm not sure what gridData is, but it is acting as if it doesn't contain the
                          data items.
                          • 10. Re: Displaying Row Number in DataGrid
                            olegkon Level 1
                            gridData is an XMLListCollection, assigned to grid.dataProvider:
                            dataProvider={gridData}
                            few lines later I do:
                            grid.dataProvider = _xlcCatalog;   [another XMLListCollection with data read from Excel file]
                            That Alert in  iterated though the data [can see it correctly], what is strange to me that for each row it shows:
                            i [aka iCol] = 0  and  rowNum [aka iIndex]= 0
                            • 11. Re: Displaying Row Number in DataGrid
                              I would debug into the getItemIndex call and see why it isn't returning the
                              right index.
