0 Replies Latest reply on Jan 25, 2010 10:33 AM by Carol L. Frampton
    [svn:fx-4.0.0] 13750: TLB Build  592.
    Carol L. Frampton Level 2
      Revision: 13750
      Revision: 13750
      Author:   cframpto@adobe.com
      Date:     2010-01-25 10:32:45 -0800 (Mon, 25 Jan 2010)
      Log Message:
      TLB Build  592.  Approved for checkin.  Includes a debuggable RSL.
      Build 592
      • Fix 2534994, transliteration by keyboard command does not work on the Mac (aborts the IME session).
      • Fix 2532163, update build file for swz generation.
      • Fix 2532451, update some file header comments.
      QE notes:
      Doc notes:
      Bugs: SDK-25223
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration:
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25223
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/air-config.xml
          flex/sdk/branches/4.0.0/frameworks/flex-config.xml
          flex/sdk/branches/4.0.0/frameworks/libs/textLayout.swc
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditMan ager.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/edit/IMEClie nt.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/factory/Stri ngTextLineFactory.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/factory/Text FlowTextLineFactory.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/factory/Text LineFactoryBase.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITab StopFormat.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITex tLayoutFormat.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/formats/TabS topFormat.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/formats/TabS topFormatInc.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/formats/Text LayoutFormat.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/formats/Text LayoutFormatInc.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/formats/Text LayoutFormatValueHolder.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/operations/I nsertTextOperation.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/branches/4.0.0/frameworks/rsls/textLayout_1.0.0.592.swf
      Removed Paths:
          flex/sdk/branches/4.0.0/frameworks/rsls/textLayout_1.0.0.591.swf
