0 Replies Latest reply on Jan 25, 2010 11:42 AM by HansMuller
    [svn:fx-trunk] 13756: Mirroring changes, fixes.
    HansMuller Level 1
      Revision: 13756
      Revision: 13756
      Author:   hmuller@adobe.com
      Date:     2010-01-25 11:42:14 -0800 (Mon, 25 Jan 2010)
      Log Message:
      - Removed ILayout interface, added mirroring API to IVisualElement.
      - Moved layoutDirection="ltr" initialization from TextBase to defaults.css.   Removed similar initialization from DefaultItemRenderer (it wasn't needed).
      - The 'get layoutDirection()' method for UIMovieClip, GraphicElement, and SpriteVisualElement now queries the parent if the local value is "inherit".
      - Use @inheritDoc instead of explicitly @copying interface methods' ASDoc.   Don't call invalidateLayoutDirection() if FlexVersion.compatibilityVersion is < 4.0.
      - Don't call invalidateLayout() for a child unless either its layoutDirection has changed, or its parent's layoutDirection has changed.
      QE notes: These changes were cycloned.
      Doc notes:
      Bugs: sdk-25204, sdk-25209
      Reviewer: Evtim
      Tests run:
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-25204
          http://bugs.adobe.com/jira/browse/sdk-25209
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualElement.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/TextBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultItemRenderer.as
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ILayoutDirection.as
