2 Replies Latest reply on Aug 9, 2012 7:37 AM by Candyce Mairs
    Split screen editing and word wrap
    <CF>
      Does ColdFusion Builder have split screen editing like Homesite+, and how do I turn it on?  How do I activate word wrap?
      Thanks much!
      Phil
        • 1. Re: Split screen editing and word wrap
          Darren T Cook
          Split screen:
          You can right-click the editor tab, and choose New Editor. This opens a second window to the same file. You can then tile them however you want.
          Word Wrap:
          Go to Window > Preferences > HTML > Editors. Click the Advanced tab and check Enable word wrap. Restart CF Builder. Unfortunately it does not appear currently possible to toggle wordwrap in any other way? But I did see a developer drop a hint they would try to make wordwrap easier.
          • 2. Re: Split screen editing and word wrap
            Candyce Mairs Level 1
            In order to see 2 files tiled at the same time within ColdFusion Builder 2, follow the steps below:
            1- Open the file
            2- Right click the tab with the file name
            3- Choose Move Editor
            4- You will see the file outlined in black in the interface, it is now attached to your cursor
            5- Click to the right of the Source tab in the open area
            6- This will allow you to view both files at the same time, one above the other
            7- The file you select will be the active file
            8- You can still use the Source and browser tabs, they will reflect whatever file is the active one
