1 Reply Latest reply on Jan 26, 2010 12:16 PM by Francisc
    Understand "Department Script" in Employee Directory [Adobe AIR app]
    Foxchx
      Ok, I ve been bashing my head around for long enough with this simple issue... I hope to find enough info to make good use of a great button in ED.
      The Department link. When viewing an employee's information in ED you can click the employee's department name and will be taken to a new panel that display all other employees in the same department. Wow, I like it....
      As much as it is good to see who else is in a department I wish I could simply use this as a static list because if I don't know the name of the employee in a specific department... well I just can't get there or take advantage of that list....
      So I went, as usual, and though I could just re-use the same script and create a static list...but, as usual, The app is way to tightly knot together that I can't seem to knock out it's relation to the employee....
      I though I would have to go back and find where it starts [IE-    dataProvider="{ department.employeees }"]   and use the dataProvider to populate my new list (in this case a datagrid)....
      Well it doesn't work, and my knowledge is too weak to figure it out as I still struggle with the syntax and it's meaning.... I think I am getting confused mostly by the  [    change="displayEmployee (event.target.selectedItem as Emlpoyee)     ] any part of script related to that change employee thingy just put out and I feel that must be the part that's linking the info to the employee at hand.
      I am out of ideas?!
      where the only way to trigger the department panel list is to open a employee from that department first...
      Here's what i am trying to do....
      Instead of clicking on the department link in the employee bio...i want to click on a button that would open a panel with a static list that never change, like the one i added at the bottom of the screenshot.
      Thank you
      Employee directory files can be found here  :
      http://download.macromedia.com/pub/developer/air/sample_apps/EmployeeDirectory.zip
      More information can be found at the original post that i made here [  http://forums.adobe.com/thread/545756?tstart=0  ]
      I created a new post as it is more clear and will be more usefull to more ppl if we find the solution.
      Thank you, again!
