1 Reply Latest reply on Jan 27, 2010 7:03 AM by Sophie_cordier
    Printing a snapshot
    BUJOE Level 1
      Hello!
      I'd like to print a snapshot of a VBox.
      Creating the image using captureBitmapData works:
           var bitmap:BitmapData =
                ImageSnapshot.captureBitmapData(vBox);
           var img:Image = new Image();
           img.source = new BitmapAsset(bitmap);
      The problem is that the image is pixellated. So I was looking for a way to increase the resolution, but keeping the final size of the image. I thought of using captureImage and setting a higher DPI value. After that I would have scaled the image back to the desired size. I Tried the following, but doesn't work:
           var imgSnapshot:ImageSnapshot =
                ImageSnapshot.captureImage(vBox, 300);
           img.source = imgSnapshot.data as ByteArray;
      The width and height of the img instance are not calculated automatically in the second case, whereas it is sone so in the first case; I'm sure that's the reason why it can't be printed.
      Am I using the captureImage method in the right way? Or has somebody any other tips to increase the resolution?
      Thanks!
