• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CSH issue - bsscdefault.h and <projectname>.ali not interacting
Guest
Jan 26, 2010 Jan 26, 2010
We recently discovered that some rather large, old Help projects seem to have lost coordination between the bsscdefault.h CSH map file and the associated .ali file that tells the project which topics are called by which CSH handles. This is a major issue for us, since we have thousands of CSH connections of this type.
I've spent a couple of hours looking for a way to force RH to associate the two but if it exists, I'm not seeing it. Any suggestions?
Thanks in advance
.MW
Views
991
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advisor ,
Hmm. Not sure I completely understand "lost coordination". Do you mean the bsscdefault.h is correct and OK, but the project name .ali is not updating when you make a change to the map .h file? Are your project .ali files blank? Or, were they created from an older version of RoboHelp?
What version of RoboHelp are you using now? I'm just fishing here, but since you mention "old" help files, I wonder if it's an encoding issue? Since RoboHelp 7, the encoding for text follows UTF-8 encoding.
Open your mis-behaving .ali files and see if the following is on the top line:
Some posts on this forum have discussed somewhat similar issues (though not exactly.) These threads may give some clues:
1st row of ALI-file does not work
http://forums.adobe.com/message/814560#814560
.ali file is empty
http://forums.adobe.com/message/701156#701156
Sorry I don't have an answer off the bat, but let's proceed with that first.
John Daigle
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Newport, Oregon
Votes
Translate
Translate
Report
Report
Guest
Hi John!
Mea Culpa. RoboHelp 8.0.2
When I say old, I meant to imply that these projects were created in RH5 and have been migrated progressively since then. When you say change the encoding is it as simple as changing the string from:
to
<?xml version="1.0" encoding="ANSI"?>
Votes
Translate
Translate
Report
Report
Guest
Apr 14, 2010 Apr 14, 2010
We're still struggling with this issue BTW. Converting the .ali file to ANSI was not the solution. The .ali file contains the Map IDs and filenames, as if there were still a connection, but the Edit Map ID's dialog box (from the Properties | Advanced tab) doesn't list the file as associated with the topic, even though the icon indicates that the Map ID is assigned to a topic.
.MW
Votes
Translate
Translate
Report
Report
Guest
Jun 01, 2010 Jun 01, 2010
This problem never went away, we just kind of left it alone for awhile. I have a question. Based on the Help in RH, I'd expect the .ali file to look like this:
rpw_table_TimeQuest_Timing_Analyzer_Summary_QRecoveryP=analyze\sta\sta_com_report_recovery_summary.htm
WED_Paste_Special=analyze\wed\wed_com_paste_spec.htm
Weak_High_QHP=analyze\wed\wed_com_dont_care.htm
When in fact, its been converted to XML:
<aliaslist version="1.0">
<alias name="Change_the_fileTs_grid_settings" link="analyze\wed\wed_com_grid.htm">
</alias>
<alias name="Waveform_Editor" link="analyze\wed\wed_view_editing_wave.htm">
</alias>
<alias name="TFW_Move_the_Master_Time_Bar_to_the_previous_logic_level_transition" link="analyze\wed\wed_com_prev_trans.htm">
</alias>
Which is what is causing our problems. Is this how it is supposed to be?
Votes
Translate
Translate
Report
Report
Guest
Jun 02, 2010 Jun 02, 2010
LATEST
For anyone that has been viewing this, I've derived a solution.
The old "value pair" line format:
mapID=<project name><optional folder name><file name>
was upgraded to the XML format in RH7, which was when we started noticing the apparent disconnect. The problem was that RH parsed the file into an alias name and a link, directly, eg.
alias name="<mapID>" link="<project name><folder name><file name>"
Our problem lay in the <project name> value, which RH didn't need to show the link between the file and the mapID. A quick manual edit to remove the <project name> value fixed everything.
.MW
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
