14 Replies Latest reply on Jan 27, 2010 2:26 PM by Darrell Loverin
    Modules not always loading at runtime
    Scott R. Hamilton Level 1
      I have a problem at run-time getting the various modules to
      load. Sometimes they do and sometimes I get the following message:
      VerifyError: Error #1014: Class mx.modules::Module not found.
          at flash.display::MovieClip/nextFrame()
          at mx.core::FlexModuleFactory/deferredNextFrame()[E:\dev\3.0.x\frameworks\projects\framework \src\mx\core\FlexModuleFactory.as:460]
          at mx.core::FlexModuleFactory/update()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\cor e\FlexModuleFactory.as:293]
          at mx.core::FlexModuleFactory/moduleCompleteHandler()[E:\dev\3.0.x\frameworks\projects\frame work\src\mx\core\FlexModuleFactory.as:526]
      If I then recompile the various components sometimes the message will go away and the
      module will load or sometimes I have to re-compile all of the components in reverse
      order normal order etc. and after 3-4 attempts all of the modules will then load at
      run time.
      Any idea what this could be?
      Scott
