2 Replies Latest reply on Jan 26, 2010 12:21 PM by Flex harUI
    remoteObject kills PopUp
    azilaga
      Added a remoteObject tag in a popup, called via PopUpManager, and now the popup doesn't come up.  Tried it in two different applications to test and it didn't work for either.  Anyone else seen this issue?
      My code to call the popUp is as follows:
          private function launcWin():void    {
              var pop1:pop_addRequest = PopUpManager.createPopUp(this, pop_addRequest, true) as pop_addRequest;
              PopUpManager.centerPopUp(pop1);
      RemoteObject:
      <mx:RemoteObject id="ro_insRequest"
          destination="ColdFusion"
          showBusryCursor="true"
          source="xxxxxxxxxx"
          result="submitResult()"
          fault="fault(event)"
          <mx:method name="insRequestbyRO">
              <mx:arguments>
                  <dt_close></dt_close>
                  <subject>{subject.text}</subject>
                  <instructions>{instructions.text}</instructions>
                  <url>{relatedURL.text}</url>
                  <clientID></clientID>
                       <snip />
              </mx:arguments>
          </mx:method>
      </mx:RemoteObject>
      I've tried modifying RemoteObject and modified launchWin() to no avail. Only consistent behavior is to remove RemoteObject to enable the PopUp again.
