3 Replies Latest reply on Jul 19, 2010 3:05 AM by uzairseedat
    Confusion on RadioButtonGroup numRadioButtons == 0, as I add them dynamically?
    rickcr
      This has me confused. I have a component that I use to generate radiobuttons and a group is added to each button as they are being built. ( After they are all built another process is supposed to iterate over the radiobuttongs in the group and mark a certain one as selected.)
      What I'm finding difficult understanding is why my radioButtonGroup.numRadioButtons is 0 even after I assign the radioButtonGroup to the created radiobButton. In fact I can't even get access to a radioButton in the group by getRadioButtonAt(index.)
      It looks it's only after everything is rendered that you have access to the radioButtons in the radioButtonGroup? If so, that's somewhat challenging... since I was hoping I could get access to the radio buttons by a reference to the RadioButtonGroup.
      As an example here is some code illustrating...
      public function build():void {
          radioButtonsBox = (layout == BaseComponentBuilder.VERTICAL) ?new VBox(): new HBox();
          this.rbGroup = new RadioButtonGroup();
          for each(var obj:* in items) {
              var r:RadioButton = new RadioButton();
              r.group = rbGroup;
              r.value = obj.@data ? obj.@data:obj.value;
              r.label = obj.@label ? obj.@label:obj.label;
              trace("rbGroup numRadioButtons afer i just added one! "+ rbGroup.numRadioButtons );//ALWAYS 0!
              trace("rbGroup rb at 0 = "+ rbGroup.getRadioButtonAt(0) );//ALWAYS null
              radioButtonsBox.addChild(r);
          parent.addChild(radioButtonsBox);
          trace("***after build() group num radio buttons = "+rbGroup.numRadioButtons); //STILL 0
        • 1. Re: Confusion on RadioButtonGroup numRadioButtons == 0, as I add them dynamically?
          archemedia Level 4
          Maybe this helps
          This code works:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" creationComplete="init()">
              <mx:Script>
                  <![CDATA[
                      import mx.controls.RadioButton;
                      import mx.controls.RadioButtonGroup;
                      import mx.containers.VBox;
                      private var rbGroup:RadioButtonGroup;
                      private function init():void
                          build();
                          var items:Array = [{value: "one", label: "labelOne"}, {value: "two", label: "labelTwo"}];
                          var radioButtonBox:VBox = new VBox();
                              r.group = rbGroup;
                              r.value = obj.value;
                              r.label = obj.label;
                              radioButtonBox.addChild(r);
                          addChild(radioButtonBox);
              </mx:Script>
          </mx:Application>
          The radioButtonGroup component is NOT a visual component so it behaves diffrently. This is probably why you don't have access immediately
          Dany
          • 2. Re: Confusion on RadioButtonGroup numRadioButtons == 0, as I add them dynamically?
            rickcr Level 1
            I figured that, but it would be cool if the API made a mention of that on the 'numRadioButtons' and 'getRadioButtonAt' functions, since it's diffently a bit puzzling at first when you try:
            var group:RadioButonGroup = new RadioButtonGroup();
            var rb:RadioButton = new RadioButton();
            rb.group = group;
            trace("rbGroupSize = "+group.numRadioButtons); //surprise not 1, but 0!
            I'll mark this question as answered if the  answer is:
            "The RadioButtonGroup does not have access to the RadioButtons until AFTER the radio buttons are rendered."
            • 3. Re: Confusion on RadioButtonGroup numRadioButtons == 0, as I add them dynamically?
              uzairseedat Level 1
              The numRadioButtons property in RadioButtonGroup does not increment unless the radio buttons are validated. If you wish immediate access to radio buttons through the group, first call validateNow( ) on each radio button.
