2 Replies Latest reply on Jan 26, 2010 11:13 PM by MamenFLASH$
    Really Really need help with flash template
    letmein1234
      Hi
      It is a template i got from template monster
      but when i open it with adobe flash i cant find which files i need to edit to add my own info
      they are all numberd file 1 file 2 and so on
      anyone out there who knows about this?
      The template is
      http://rapidshare.com/files/340890326/22967.rar
      so if somebody can have a look at at and tell me what files i need to edit
      that would be great
      kind regards
      james
        • 1. Re: Really Really need help with flash template
          If it is a Flash site, then you primarily want to edit whatever Flash source files come with the template--files with an .fla extension, although there may be some data files that contain content such as .xml files.
          As far as where to look within the Flash source files goes, there's a world of possibilities in where you'll find the content you need to change.
          If the file uses timelines, it may be easiest to first move along the timeline and see if you can find the content.  You may need to hide any mask layers to see things.
          It is also possible the file loads content dynamically from the library, in which case you'll need to dig thru the library to try to find the content.
          There's also the possibility that text content is added via actionscript code.  This code could be in the timeline, or if your file uses AS2 it could be attached to buttons, or it could be in separate actionscript files, or it could be in any separate data files (xml, txt, etc).
          If your template is a complicated design, it could be tricky finding things, so what you might try as an approach is to retain an original copy of all the files safely somewhere and tear apart a copy of them without mercy until you find what you need.  That way you don't have to fear breaking anything... always work on copies and retain an untouched master.
          • 2. Re: Really Really need help with flash template
            MamenFLASH$ Level 1
            Hi. Yes, I have done it myself. You have to look for all the ".fla"
            files. You can just open them in your FLASH and customize them.
            MamenFLASH
            El 26/01/2010, a las 23:15, letmein1234 escribió:
            Hi
            The template is
            to edit
            that would be great
            kind regards
            james
