1. Re: Form Toolbar in CS4?
Zabeth69 Jan 26, 2010 6:24 PM (in response to Mike_Watt)You're looking for the Form Insert Panel.
Although the Insert Panel typically may be docked on the right side of the workspace, and different Insert Panels selected from there, you can also drag it over and dock it at the top, above your document window. Then the different Insert Panels show up as tabs, and the contents of each shows up as a toolbar across the top of your page.
Do Window > Insert if the Insert Panel is not showing, then drag by the dark grey bar and drop when you get a blue halo above the grey bar.
Beth
2. Re: Form Toolbar in CS4?
Mike_Watt Jan 28, 2010 6:15 PM (in response to Zabeth69)Thank you. I actually had that panel open, but it was set to "Common" - I didn't realize that I needed to actually click "Common" to change it to "Form" - thanks for the info!
3. Re: Form Toolbar in CS4?
Zabeth69 Jan 28, 2010 7:19 PM (in response to Mike_Watt)Yeah, all those toolbars are now in the same panel.
B
