0 Replies Latest reply on Jan 26, 2010 2:55 PM by Chet Haase
    [svn:fx-4.0.0] 13791: Fix to situation where Rotate3D+Move+Resize could result in snapping artifacts after the effect ends .
    Chet Haase Level 3
      Revision: 13791
      Revision: 13791
      Author:   chaase@adobe.com
      Date:     2010-01-26 14:55:03 -0800 (Tue, 26 Jan 2010)
      Log Message:
      Fix to situation where Rotate3DMoveResize could result in snapping artifacts after the effect ends. The problem is that the use of a simple Move (vs. Move3D) caused the xy values to be animated, but the Z value to be picked up dynamically. But since the object is being resized, the Z value is always one frame out of date, resulting in compound errors during the course of the effect.
      QE notes: None
      Doc notes: None
      Bugs: sdk-25211
      Reviewer: Jason
      Tests run: checkintests, Mustella spark/effects, transform effect manual test matrix
      Is noteworthy for integration: Yes - requested by downstream tools team
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-25211
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/effects/supportClasses/Animat eTransformInstance.as
