0 Replies Latest reply on Jan 26, 2010 5:47 PM by jdesko
    Using chromeColor in a component with a custom skin Error
    jdesko Level 2
      If you have a Spark TitleWindow that you put in its controlBarContent a Spark ButtonBar, and this ButtonBar uses a custom skin that you want to display an icon(graphics) instead of a label, you cannot use the TitleWindow's property chromeColor.  When chromeColor is set it looks for a Label id="labelDisplay" in its child components/skins (see below).
      The fix was to keep the Label in the custom skin in layer 8: text, but set its includeInLayout = false and visible = false.
      So this will cause an error:
      ?xml version="1.0" encoding="utf-8"?>
      <s:TitleWindow xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/mx"
         chromeColor="0x272727">
      <s:controlBarContent>
      <s:ButtonBar id="textAlign_BtnBar"
      arrowKeysWrapFocus="true"
      labelField="label"
      width="80"
      requireSelection="true"
      focusEnabled="false"
      skinClass="skins.AlignButtonBarSkin"
      change="textAlign_BtnBar_changeHandler(event)" >
      <s:ArrayList>
      <fx:Object label="Left" value="{TextAlign.LEFT}" icon="@Embed('assets/images/leftAlign.gif')"/>
      <fx:Object label="Center" value="{TextAlign.CENTER}" icon="@Embed('assets/images/centerAlign.gif')"/>
      <fx:Object label="Right" value="{TextAlign.RIGHT}" icon="@Embed('assets/images/rightAlign.gif')"/>
      <fx:Object label="Justify" value="{TextAlign.JUSTIFY}" icon="@Embed('assets/images/justifyAlign.gif')"/>
      </s:ArrayList>
      </s:ButtonBar>
      </s:controlBarContent>
      </s:TitleWindow>
      And the custom skin (only showing partial code):
          <!-- layer 8: text -->
      <s:Graphic id="icon_Group"
         horizontalCenter="0" verticalCenter="0"
         toolTip="{hostComponent.data.label}">
      <s:BitmapImage id="icon_Bmp" source="{hostComponent.data.icon}"
         scaleX="0.5" scaleY="0.5"/>
      </s:Graphic>
      </s:SparkSkin>
