3 Replies Latest reply on Jan 27, 2010 7:03 PM by fuzzyericlim
    Problem with loading font in Javascript command: appliedFont
    fuzzyericlim
      hi, i have write a javascript to run in indesign cs4. I have loaded 3 font family: Trajan, Helvetica and New Caledonia
      As i am step thru' the code to load the font, i encounter strange problem:
          var sty = doc.paragraphStyles.add({name:styName});
          sty.appliedFont = "Trajan";  // -- always ok. It has a "Regular" style. I can use any other font as long as has "Regular" style
      // however the immediate code will fail as it complains "The requested font family is not available" .
      // It will only work if in Indesign, i select the font type to "New Caledonia" before the step thru the code
          sty.appliedFont = "New Caledonia";
      // The code will again fail  as it complains "The requested font family is not available" UNLESS i select the Font in Indesign as  "Helvetica" too
      // Very very strange...
          sty.appliedFont = "Helvetica";
      However, if i use the 3 fonts family that has a "Regular" style , the 3 line of code will be ok...
      Both the Helvetica and New Caledonia DOES NOT have "Regular" style..
      HELP
        • 1. Re: Problem with loading font in Javascript command: appliedFont
          fuzzyericlim Level 1
          I am using Window version of Indesign CS4...
          • 2. Re: Problem with loading font in Javascript command: appliedFont
            Hi, fuzzyericlim!
            Use "fontStyle" for your font weight to define the style as well.
            Example:
            sty.appliedFont = "Univers";
            sty.fontStyle="55 Roman";
            Uwe
            • 3. Re: Problem with loading font in Javascript command: appliedFont
              hi Uwe, i think i didnt write clear enuff...
              i have installed Trajan, Helvetica and New Caledonia into my PC.
              When i launch CS4 , i can see that Trajan has Regular style but not the other 2 ( which i dont know why. I can see it in WinWord)
              i step thru my script using ExtendScript ToolKit using the below script snippet to test the 3 font.
              When i step to "Trajan" line, it's ok. But the next step will fail, which i dont understand. I have New Caledonia font.
              But it complaint "The requested font family is not available"..
              Now, before i  step thru the script again, i purposely go to ID CS4 to set the font menu to "New Caledonia" ( at the top left hand corner )
              Now when i step thru, the "Trajan and "NEw Caledonia" line is ok, BUT the script will fail at the next "Helvetica" line...
              Strange enuff...i am lost...
              However, if i change to following script, it will step thru successfully...All the below 3 fonts has "Regular" style
                  sty.appliedFont = "Times New Roman";
                  sty.appliedFont = "Arial";
              Any advise?? =(
              Message was edited by: fuzzyericlim
