6 Replies Latest reply on Jan 28, 2010 12:30 AM by Harbs.
    [CS4] Export to ePub/eBook
    Caerwyn Level 1
      I can export to pdf and eps via visual basic.
      It's possible from the File menu to Export to Digital Editions, how do I do the same from the scripting interface.
      ie; export to ePub/Book.
      Thanks for any help
      Caerwyn
        • 1. Re: [CS4] Export to ePub/eBook
          AdobeScripts Level 3
          hi
          Sub Export(Format, To As String, [ShowingOptions As Boolean = False], [Using], [VersionComments], [ForceSave As Boolean = False])
              Member of InDesign.Document
              Exports the object(s) to a file.
              Format: The export format, specified as an enumeration value or as an extension that appears in the Save as type or Format menu in the Export dialog. Type: idExportFormat enumerator or String.
              To: The path to the export file.
              ShowingOptions: If true, displays the export options dialog.
              Using: The export style. Type: PDFExportPreset.
              VersionComments: The comment for this version. Type: String.
              ForceSave: If true, forcibly saves a version.
          and as Format - I think this should be right:
          Const idPackagedXFL = 1702389356 (&H6578666C)
              Member of InDesign.idExportFormat
              Exports to packaged XFL format.
          For setting extra options:
          Class XFLExportPreference
              Member of InDesign
              XFL export preferences.
          robin
          www.adobescripts.co.uk
          • 2. Re: [CS4] Export to ePub/eBook
            Peter C Hayward
            Well so far so bad!
            I can create a file with the epub extension but it's not an epub file.
            import win32com.client, pythoncom
            def main():
                Script entrypoint
                myInDesign=win32com.client.Dispatch('InDesign.Application.CS4')
                myDocument = myInDesign.Documents.Add()
                myPage = myDocument.Pages.Item(1)
                myTextFrame = myPage.TextFrames.Add()
                myTextFrame.GeometricBounds = ( '6p', '6p', '24p', '24p' )
                myTextFrame.Contents = "Hello World!"
                myFilePath = "C:\Incoming\Test_eBook.epub"
                myDocument.Export( idPackagedXFL, myFilePath )
            if __name__ == '__main__':
                main()
            If I use the menu option to export the same created file and then compare the binaries then the real file has the text
                 mimetypeapplication/epub+zipPK
            but the file created by the python script contains
                 mimetypeapplication/vnd.adobe.xflPK
            I'm sure this must be possible.
            I've looked through the type lib and I can't see an epub file type.
            Yet I think it's unlike Adobe to put Export for Digital Editions in the menu and not make it scriptable.
            • 3. Re: [CS4] Export to ePub/eBook
              Caerwyn Level 1
              Sorry, I didn't realise that the PC was logged into my colleagues account!
              That last reply was actually from me.
              Caerwyn
              • 4. Re: [CS4] Export to ePub/eBook
                It's not mentioned anywhere in the Scripting help. Perhaps it's a similar trick as Export To Dreamweaver -- an integrated Javascript, rather than a "real" plugin. The InDesign SDK has lots of information on the Dreamweaver export, including its javascript sources, so you could take a peek in there.
                • 5. Re: [CS4] Export to ePub/eBook
                  I'm sorry for misunderstanding I've never used this options and it was only guess
                  XFL is for Flash export.
                  Now after more precise inspection of ObjectBrowser (VB6) - I don't see anything related to ePub - so this is probably done by some plugin ...
                  I think I found it there is few scripts located in:
                  [install path to CS4]\Adobe InDesign CS4\Scripts\XHTML For Digital Editions\
                  and in ..\Adobe InDesign CS4\Scripts\XHTML For Digital Editions\startup scripts\OEBExportMenuItemLoader.jsx
                  there is:
                  // Purpose: Export InDesign documents to epub files or Digital Editions
                  but all other scripts are as JSXBIN ...
                  robin
                  www.adobescripts.com
                  • 6. Re: [CS4] Export to ePub/eBook
                    Harbs. Level 6
                    The export for Digital Editions is itself a script, and therefore not
                    really scriptable...
                    Harbs
