5 Replies Latest reply on Jan 29, 2010 2:41 AM by George Medve
    Multilingual captioning, how?
    George Medve
      I am creating a CD-Rom presentation, the requirements of which are Video and multi-language captioning.
      I thought this would be a good opportunity to gain experience with OSMF and the Captioning Plugin.
      I am an FDT user rather than Flash Builder and have rebuilt the CaptioningSample example as a Pure AS3 project, swapping Flex components for Flash CS3 components. Everything compiles and video with captioning works well.
      For the next step I want to add be able to switch between various captioning languages, but I can not see how I would go about adding this functionality.
      I think I am going about this the wrong way and that there is probably a simpler way of doing this, but below is what I have tried.
      I presumed that I would need to load all of the DFXP documents in advance. Then when the user selects a language the captionLabel textfield is populated with the correct caption.
      I thought adding a value to kvFacet might work, but this always displays the last value entered.
      // adapted from CaptioningSample.mxml line 118 in the loadMedia method
      kvFacet.addValue ( new ObjectIdentifier ( CaptioningPluginInfo.CAPTIONING_METADATA_KEY_URI ), CAPTION1_URL );
      kvFacet.addValue ( new ObjectIdentifier ( CaptioningPluginInfo.CAPTIONING_METADATA_KEY_URI ), CAPTION2_URL );
      I have also tried changing th key used in  new ObjectIdentifier ( 'lang1' )but I cannot see where I would check against this new value.
      Could anyone offer some assistance on this matter please?
      Thanks in advance,
      George
        • 1. Re: Multilingual captioning, how?
          George Medve Level 1
          I am starting to wonder..... is this even possible in this release of OSMF?
          I have been trying all sorts of hacks and trying to got through the classes to see if
          I can try and get it to work, but my understanding of the frame work is quite limited.
          Can anyone offer any assistance?
          • 2. Re: Multilingual captioning, how?
            bringrags Level 4
            Couldn't you select the language up front and then assign the appropriate language-specific XML document to the metadata facet as the caption URL?
            // Set the caption URL based on the selected language.
            var captionURL:String = ...
            // Assign to the resource the metadata that indicates that it should have a Timed Text
            // document applied (and include the URL of that document).
            var kvFacet:KeyValueFacet = new KeyValueFacet(CaptioningPluginInfo.CAPTIONING_METADATA_NAMESPACE);
            kvFacet.addValue(new ObjectIdentifier(CaptioningPluginInfo.CAPTIONING_METADATA_KEY_URI), captionURL);
            resource.metadata.addFacet(kvFacet);
            • 3. Re: Multilingual captioning, how?
              Hi Brian,
              Thanks again
              It is an idea but ideally I think the client would like to be able to switch at while the video is playing.
              The funny thing is that I have managed to get it working with the CS3 FLVPlayback & FLVPlaybackCaptioning components by simply adding 2 instances of the FLVPlaybackCaptioning component. I did have some minor tweaks to sort but it works well.
              I don't think that the current implementation of the Caption Plugin has been designed with this in mind.
              It is a shame as I was quite looking forward to trying out OSMF.  Maybe once it has matured some more.
              If any one has any ideas then I am interested in hearing them
              George
              • 4. Re: Multilingual captioning, how?
                bringrags Level 4
                You're right, dynamic switching of captioning files is not currently supported.  Can you file an enhancement request here?
                https://bugs.adobe.com/jira/browse/FM
                Thanks!
