1 Reply Latest reply on Jan 27, 2010 10:29 AM by Mylenium
    Problem with royal render using expression in after effects
    authenticvg
      Hi
      We're using after effects 7.0 with royal render. All seems ok but Wee got problem with some expressions. 1st we thought it was a problem of language but we install an english version and we still have trouble. Simple expressions like equal works but we have made an organisation with slider and even a simlple slider is not calculate when we use network rendering (with royal render).
      Does someone know what we do wrong ?
        • 1. Re: Problem with royal render using expression in after effects
          Most likely still a language issue. Expression controls use the default system language, so a "Slider" mnay still turn into "Schieberegler" on a German system for instance and break the expression. Make sure to add the -L EN command line parameter when running English expressions, use the other language identifiers as needed (FR, ES, DE, JP, IT). _also make sure you are not using special characters when naming your effects controls.
          Mylenium
