8 Replies Latest reply on Jan 28, 2010 4:28 AM by ramkumar.vp
    Insert XML Image into Table Cell
    Marco Lugli
      Hello all,
      I have an xml file of products including references to the image of each product.
      I'm trying to transform the xml into a table after import into Indesign CS3.
      Here's the general structure of the xml:
      <Root>
      <Product>
        <Image href="file://./00257-00257.tif"/>
        <Code>00257</Code>
        <Price>126,00</Price>
      </Product>
      </Root>
      And here's my script:
      function main(){
           var myDocument = app.activeDocument;
          //Add tag elements
          var myRowTag = myDocument.xmlTags.add("row");
          var myCellTag = myDocument.xmlTags.add("cell");
          var myTableTag = myDocument.xmlTags.add("table");
          //Add XML elements.
          var myRootXMLElement = myDocument.xmlElements.item(0);//Root
          var myProducts = myRootXMLElement.xmlElements;
          //Create elements for table
          with(myRootXMLElement){ //First with
              var myTableXML = xmlElements.add(myTableTag);
              with(myTableXML){
                  for(var myRowCounter = 0; myRowCounter < myProducts.length -1; myRowCounter++){ //First for
                      var myProducts = myRootXMLElement.xmlElements.item("Product");
                      var myProduct = myProducts[myRowCounter];
                      with(xmlElements.add(myRowTag)){ //Second with
                          var myProductXMLElements = myProduct.xmlElements;
                          for(var myCellCounter = 0; myCellCounter < myProductXMLElements.length; myCellCounter++){ //Second for
                              with(xmlElements.add(myCellTag)){ //Third with
                                  var contents = myProductXMLElements[myCellCounter].contents;
                              } //end of third with
                          } //end of Second for
                      } //end of second with
                  } //end of di First for
              } //end of first with
          //Remove old tags from Structure
          myProducts.remove();
          //Create table
          var myTable = myTableXML.convertElementToTable(myRowTag, myCellTag);
      main();
      Here's the result (inside Indesign):
      <Root>
        <table>
         <cell></cell>
         <cell>00257</cell>
         <cell>126.00</cell>
        </table>
      </Root>
      The problem is I can't insert the image into its cell: any suggestions?
