1 Reply Latest reply on Aug 31, 2007 10:41 AM by ebelair
    How can I pass Array to java server though web service
    aprildavid
      Can We pass Array to web service? I always failede. Need your help!!!!
        • 1. Re: How can I pass Array to java server though web service
          ebelair Level 1
          I got this script from someone else, but I think it is basically what you are looking for, though, this uses a Function in a ColdFusion Component as the WebService.
          Basically, you create an Object, then populate the Object as an Associative Array, then create an Operation to call the WebService, then call the WebService. The name of each item in the Object must match the name of the argument in the WebService, and you must pass every argument to the WebService (simply set it to [empty string] ("") if you do not have a value for any of the arguments.
          Good luck.
