1 Reply Latest reply on Sep 21, 2007 10:21 AM by kglad
    AS3 limitation
      Could you tell me the limitation in AS3 ? For example, how many "Sprite" can i use in an another "Sprite" ? Where can i find all limitations in the langage AS3 ?
        • 1. Re: AS3 limitation
          i don't think the limit is the number of sprites. it's going to be the time require to create them that will cause a (timeout) problem. and if they are display objects the cpu used to display them will cause problems (system hang).
