• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Remove unwanted characters before entering database?
Participant ,
Jan 27, 2010 Jan 27, 2010
I usually remove udnesirable special characters that could be entered in a form before submitting to a database with this
<cfset variable = #Replace(variable,"%","", "all")#>
is there a better way I could simply list all of the unwanted values and just replace from that list?
TOPICS
Advanced techniques
Views
502
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Jan 28, 2010 Jan 28, 2010
The safetext function at cflib.org might help you.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Feb 15, 2010 Feb 15, 2010
I use something like this (below) to not only replace characters, but entire words from strings.   I use mostly use this code to replace 'bad words' in moderated forums with 'alternative text'.
Assume you have a field called 'newdata' for your user to fill out, and they type the following:
"In 99% of the studies, someone always badwords ^ the flow of the discussion"
Run this against the 'newdata' field before inserting it into the database (or before displaying it on the screen if you want to show it before it is inserted)
<cfset fixeddata = '#ReplaceList(newdata, "%,^,badword"," percent,up,goodword")#'>
The result, if you output the resulting #fixeddata# would read:
"In 99 percent of the studies, somoene always goodwords up the flow of the discussion"
All kinds of possibilities with this.
Hope it helped,
WHeis
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
There's replaceList() or reReplace() which could be used here.
Adam
Votes
Translate
Translate
Report
Report
Resources
Documentation
