6 Replies Latest reply on Jan 28, 2010 4:30 PM by the_wine_snob
    Render, Preview?? Help!
    CT2the3
      Hello, i just downloaded premiere elements 8, and I inserted some video clip, pushed play, and the video lagged a WHOLE bunch. The audio seemed fine, but the video was just really bad. So i did "render work area". And it played back fine, but took a lonnnnnnnnnng time. Do i have to render it everytime before i can preview my work?
      Anything would be greatly appreciated!
      ~CT
        • 1. Re: Render, Preview?? Help!
          It depends on what kind of camcorder your video came from and which project settings you're using.
          If your video is from a traditional tape based miniDV or HDV camcorder, you only have to render if you add effects.
          If your video is from an AVCHD camcorder, you will likely have to render -- but this type of video can demand a quad core processor to work with anyway, so rendering shouldn't take too long.
          Other video -- such as video from Flip camcorders or from still cameras -- probably ought to be converted to a more standard format before you bring them into Premiere Elements.
          • 2. Re: Render, Preview?? Help!
            CT2the3 Level 1
            Mine is an AVCHD Camera, and i am running a dual core processor. So would that be y it takes so long to render?
            • 3. Re: Render, Preview?? Help!
              Yes. Most likely. As I say, AVCHD is probably the most challenging format to edit on a PC. It takes at least a quad core processor to do it without a lot of sitting and waiting. Sorry.
              • 4. Re: Render, Preview?? Help!
                CT2the3 Level 1
                Alright, one more qiuck question. is it possible to show two diffrent clips at the same time in my project?
                • 5. Re: Render, Preview?? Help!
                  nealeh Level 5
                  Yes. Add the second footage to another video track. Then vary motion (where you can set position and size) and opacity - both standard properties of every clip. Then add other effects as necessary. I think the maximum number of video tracks is 99 in PRE.
                  Cheers,
                  Neale
                  • 6. Re: Render, Preview?? Help!
                    the_wine_snob Level 9
                    The term for this is PiP (Picture in Picture). Neale has given you the most common way to do this. There are a few others, should his instructions not be quite what you want. I do not recall the version of PrE that you have, but in the later versions, there are even PiP Presets, though I find that doing my own offers far more control, and I can exercise both my artistic and technological license.
