3 Replies Latest reply on Jan 28, 2010 12:09 PM by Kathlene Ruhan
    Multipages pdf place in ractangel frame
    2008Mac
      Hi All
      Is there any work around this that i want to import x PDF file in rectangels instead of pages.
      I tried with given code but it's place first page repeatedly in all rectangels.
      main();
      function main(){
      //var myCounter = 1;
      var myDocument = app.documents.item(0);
      var myPage = myDocument.pages.item(0);
      var myPDFFile = File.openDialog("Choose a PDF File");
      var myRectangles = myDocument.rectangles.everyItem();
      if((myPDFFile != null)){
      myPlacePDF(myDocument, myRectangles, myPDFFile);
      function myPlacePDF(myDocument, myRectangles, myPDFFile){
      var myPDFPage;
      //app.pdfPlacePreferences.pdfCrop = PDFCrop.cropMedia;
      var myCounter = 1;
      var myBreak = false;
      while(myBreak == false){
        if(myCounter > 1){
         myPage = myDocument.pages.add(LocationOptions.after, myPage);
        app.pdfPlacePreferences.pageNumber = myCounter;
        myPDFPage = myRectangles.place(File(myPDFFile), false)[0];
        if(myCounter == 1){
         var myFirstPage = myPDFPage.pdfAttributes.pageNumber;
        else{
         if(myPDFPage.pdfAttributes.pageNumber == myFirstPage){
          myPage.remove();
          myBreak = true;
        myCounter = myCounter + 1;
      Many Thanks in advance
      Subhendu
        • 1. Re: Multipages pdf place in ractangel frame
          ramkumar.vp
          Hi Subhendu,
          in your script variable "myPDFPage" is getting a array.
          So you can use  var myFirstPage = myPDFPage[0].pdfAttributes.pageNumber;
          And also "myRectangles" is collection of all Rectangles. If you use the for loop to place PDF (page by page) then only it place the pdfs sequentially.
          Regards,
          Ramkumar .P
          • 2. Re: Multipages pdf place in ractangel frame
            Shonkyin Level 3
            Hi Subhendu,
            Please check below code:
            main();
            function main(){
            var myPDFPage;
            var myCounter = 1;
            for (a=myDocument.rectangles.length-1; a>=0; a--)
            myDocument.rectangles[a].place(File(myPDFFile), false)[0]
            Shonky
            • 3. Re: Multipages pdf place in ractangel frame
              Kathlene Ruhan Level 3
              What program are you placing these images into?
