1 Reply Latest reply: Jan 27, 2010 8:13 PM by waterdad568 RSS
    image quality in Flash
    k.loy Community Member
      What's the best way to maintain image quality in Flash.
      The images in this  banner gallery just don't look as good as they do on my computer.
      Is there a way to embed color profile in the Flash import?
      http://www.michaelmcdonalddesigns.com/
        • 1. Re: image quality in Flash
          waterdad568 Community Member
          If your are purely trying to maintain image quality and your not so concerned about file size, when you import your images to the library, and double click them or open the bitmap properties panel for that image, you have several properties available, for best image quality under the compression menu choose lossless png/gif. You can also experiment with the allow smoothing check box if images are pixelating, and you can also try a custom compression quality up to 100 with a photo/jpg. Each higher setting will also the increase the file size.
          Try the lossless png/gif setting first, and import high quality unresized photos, if the movie still loads and plays fine, that will probably be your best quality.
