5 Replies Latest reply: Jan 28, 2010 1:15 PM by kglad RSS
    preloader script
    k.loy Community Member
      I'm trying to build a preloader.
      I made a scene in the FLA called preloader and inserted the following script.
      The problem is that I got the preload animation and the script from 2 different tutorials.
      The problem I think lies in the fact that I think the code I am using requires a 100 frame animation, and I am only using a 25 frame animation.
      I tried adding frames to the animation to make it 100 frames , but it still doesn't work.
      --I followed the scripting instructions from this tutorial
      http://www.flashmagazine.com/Tutorials/detail/how_to_make_a_custom_as3_preloader/
      --I got the preload animation from this one. Though I am only using the animation, not the dynamic text field.
      http://active.tutsplus.com/tutorials/web-design/create-an-apple-inspired-flash-preloader/
      Here is an attachment with the FLA, and the code in the preloader scene is below.
      Any help is appreciated. Thanks
      import flash.events.ProgressEvent;
      function update(e:ProgressEvent):void
      var percent:Number = Math.floor( (e.bytesLoaded*100)/e.bytesTotal );
      if(preloaderMC is MovieClip){
      preloaderMC.gotoAndStop(percent);
      if(percent == 100){
      play();
      loaderInfo.addEventListener(ProgressEvent.PROGRESS, update);
      // Extra test for IE
      var percent:Number = Math.floor( (this.loaderInfo.bytesLoaded*100)/this.loaderInfo.bytesTotal );
      if(percent == 100){
      nextFrame();
      stop();
        • 1. Re: preloader script
          kglad CommunityMVP
          don't add any unneeded frames to preloaderMC and use:
          function update(e:ProgressEvent):void{
          var fraction:Number = e.bytesLoaded/e.bytesTotal;
          preloaderMC.gotoAndStop(Math.ceil(fraction*preloaderMC.totalFrames));
          function loadCompleteF(e:Event){
          play();
          loaderInfo.addEventListener(Event.COMPLETE, loadCompleteF);
          stop();
          • 2. Re: preloader script
            Thanks, though I put this script in and it doesn't seem to be working.
            I uploaded the .swf with the preloader and this script on to the site, but the area is still white while it's loading and then it plays the actual scene.
            Am I doing something wrong?
            • 3. Re: preloader script
              kglad CommunityMVP
              your preloader won't display until all items designated to load in frame 1, have loaded.  that includes all classes and embedded fonts so, if you have a lot of those things, you're not doing anything wrong.  that's just expected with an internal preloader and your setup.
              otherwise, you're doing something wrong.
              • 4. Re: preloader script
                the preloader is pretty simple just a 25 frame movie clip vector animation, no text and your script.
                I'm supposed to put that code in frame 1 of the preloader scene ---right? Not the main scene.
                • 5. Re: preloader script
                  kglad CommunityMVP
                  if you're using scenes, the preloader and preloader code should be in the first frame of the first scene.  what you call your scenes is irrelevant.
