5 Replies Latest reply on Sep 6, 2007 3:40 AM by Newsgroup_User
    Dreamweaver/Fireworks javascript error
    lucyo Level 1
      I've been using Fireworks and Dreamweaver for a while.
      I'm rebuilding our website, and made my navigation bar/buttons in Fireworks just like I did on the previous page.
      exported as html.
      then I went to dreamweaver and inserted fireworks html... The buttons worked for a while. one day when I was home I thought I'd work on it some more, and ever since, whenever I insert the button, i get this error...
      "while executing object tag in fireworks html a javascript error occured"
      i can even start with a blank html file and insert any fireworks file, even the one that works on the current site, and I get that error.
      I created a new simple button, and still get that error...
      The only thing I can think of that's might could have caused this... at work I have the newer CS3 suite and Dreamweaver 4, and at home I just have Dreamweaver 4.
      Could something have caused this by using both versions when working on this new site?
        • 1. Re: Dreamweaver/Fireworks javascript error
          Level 7
          That's a bad start. The FW menus are legendary for their inadequacies.
          When you look up that word "inadequate" in the dictionary, you see a picture
          of FW menus. 8)
          > exported as html.
          It's ALWAYS a bad idea to allow a graphics editor write your HTML.
          Troubleshooting JavaScript errors in Dreamweaver
          http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_19105#dat
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "lucyo" <webforumsuser@macromedia.com> wrote in message
          news:fbl5tc$34d$1@forums.macromedia.com...
          > Fireworks
          > exported as html.
          > worked
          > and
          > even
          > work I
          > Dreamweaver
          > 4.
          > this
          > new site?
          • 2. Re: Dreamweaver/Fireworks javascript error
            lucyo Level 1
            somewhere while i was searching for an answer, i read when a fireworks html file is removed, it leaves remnants of the original file, so that when you reinsert it, there are problems...
            i do wish you could just higlight the gif to remove it and it was all gone, instead of every time having to go into code view and figure out what to take out and what to leave...
            and if i could find a better way to make my navigation bar, i'd do it. since this is what i learned before and it worked, i used this method again since i knew it worked.
            never had this problem for the past few years til now.
            • 3. Re: Dreamweaver/Fireworks javascript error
              Level 7
              > html
              Huh? You mean when you delete an image from a page? Baloney.
              > gone,
              You certainly can do this.
              Check the uberlink and MacFly tutorials at PVII -
              and the Navbar tutorial/articles at Thierry's place
              http://tjkdesign.com/articles/dropdown/
              Or this one (more recent article):
              http://tjkdesign.com/articles/Pure_CSS_Dropdown_Menus.asp
              Or to get it done fast, go here -
              http://www.projectseven.com/tutorials/navigation/auto_hide/index.htm
              You always had problems, you just didn't know about them. But your visitors
              and search engines did....
              news:fbngl3$phm$1@forums.macromedia.com...
              > html
              > gone,
              > take
              > since
              > since i
              > knew it worked.
              • 4. Re: Dreamweaver/Fireworks javascript error
                lucyo Level 1
                quote:
                >> html
                it leaves some javascript code in there... when i went into code view and deleted all of that, and reinserted the edited fireworks html, it worked fine.
                >> gone,
                i'm not sure if its not working because i'm using a newer fireworks/dreamweaver or why it isn't working now but it did before.
                thanks i will check them out...
                well at least i have this page w3c validated... even with the fireworks html navigation bar.
                when i was building the original website, i didn't have a clue about how to do that even, so i've learned a little and its from having problems like this and searching for answers.
                maybe if someone else has this problem they will realize to look at the code and see where it leaves some of the javascript or fireworks html even after the image is removed... and when they remove that code and reinsert the fireworks html it doesn't give an error or lock up fireworks...
                • 5. Re: Dreamweaver/Fireworks javascript error
                  Level 7
                  Oh. I see.
                  Way better than the FW menus.
                  Good luck.
                  news:fbnkrp$d2$1@forums.macromedia.com...
                  > >> html
                  > >> you
                  > fine.
                  > >> gone,
                  > >visitors
                  > html
                  > navigation bar.
                  > to do
                  > and
                  > code
                  > after the
                  > fireworks
