4 Replies Latest reply on Jan 31, 2010 8:58 PM by legrosb
    flexunit task hangs after "Receiving data ..."
    Adnan Doric Level 1
      Hello,
      I am trying to launch the Ant script found in FlexUnit4SampleCIProject but it just doesn't works.
      Last message in console is "[flexunit] Receiving data ..." and the tests in the UI are not started and showing 0/100.
      I am using latest standalone debug flash player : flashplayer_10.0.42.34_sa_debug.exe
      I use flextasks from Flex4 4.0.0.13549 as the flexTasks.jar that comes with the project doesn't work:
      BUILD FAILED
      X:\wb_fb4\FlexUnit4SampleCIProject\build.xml:47: The class not found in jar file: mxmlc.jar
      Buildfile: X:\wb_fb4\FlexUnit4SampleCIProject\build.xml
      init:
      compile:
          [mxmlc] Loading configuration file F:\Program Files (x86)\Adobe\Adobe Flash Builder Plug-in Beta 2\sdks\4.0.0.13549\frameworks\flex-config.xml
          [mxmlc] X:\wb_fb4\FlexUnit4SampleCIProject\target\bin\Main.swf (469843 bytes)
      test:
          [mxmlc] X:\wb_fb4\FlexUnit4SampleCIProject\target\bin\TestRunner.swf (989770 bytes)
      [flexunit] Validating task attributes ...
      [flexunit] Generating default values ...
      [flexunit] Using default snapshot file path [X:\wb_fb4\FlexUnit4SampleCIProject\target\report\snapshot.jpg]
      [flexunit] Using the following settings:
      [flexunit]     haltonfailure: [false]
      [flexunit]     headless: [false]
      [flexunit]     localTrusted: [false]
      [flexunit]     player: [flash]
      [flexunit]     port: [1024]
      [flexunit]     snapshot: [false]
      [flexunit]     snapshotFile: [X:\wb_fb4\FlexUnit4SampleCIProject\target\report\snapshot.jpg]
      [flexunit]     swf: [X:\wb_fb4\FlexUnit4SampleCIProject\target\bin\TestRunner.swf]
      [flexunit]     timeout: [60000ms]
      [flexunit]     toDir: [X:\wb_fb4\FlexUnit4SampleCIProject\target\report]
      [flexunit]     verbose: [true]
      [flexunit]     xcommand: [xvfb]
      [flexunit] Setting up server process ...
      [flexunit] Starting server ...
      [flexunit] OS: [Windows]
      [flexunit] Launching player:
      [flexunit] Executing 'rundll32' with arguments:
      [flexunit] 'url.dll,FileProtocolHandler'
      [flexunit] 'X:\wb_fb4\FlexUnit4SampleCIProject\target\bin\TestRunner.swf'
      [flexunit] The ' characters around the executable and arguments are
      [flexunit] not part of the command.
      [flexunit] Opening server socket on port [1024].
      [flexunit] Waiting for client connection ...
      [flexunit] Client connected.
      [flexunit] Setting inbound buffer size to [262144] bytes.
      Here I can wait long time, and if I close the UI, i get those bonus lines :
      [flexunit]
      [flexunit] Stopping server ...
      [flexunit] End of test data reached, sending acknowledgement to player ...
      [flexunit] Closing client connection ...
      [flexunit] Closing server on port [1024] ...
      BUILD FAILED
      X:\wb_fb4\FlexUnit4SampleCIProject\build.xml:68: java.util.concurrent.ExecutionException: java.lang.NullPointerException
      Total time: 53 seconds
      Am I doing something wrong?
      Thank you in advance for your help,
      Adnan
