12 Replies Latest reply on Jan 29, 2010 8:02 AM by Daniel Pride
    Mac to GoDaddy Linux Zend Deployment problems
    Daniel Pride Level 1
      I develop on a Macintosh (localhost) and deploy to GoDaddy Linix
      I did the following, exactly but it does not work.
      I am on beta 2  - What am I missing?
      Help please this is a demo to close a deal with a client.
          copied  ZendFramework/  to  server root
          exported release build to local HD
          Copied  build folder to server root
          copied the missing services folder from bin-debug to the build folder on the server
          ---- amf-config.ini ------
                  Uncommented and set zend_path to absolute path ( http://www.danielpride.com/ZenFrameworks )
                  Set amf.production to true.
                  Set Webroot to (  http://www.danielpride.com )
      Note: there is no fml file to be seen on my entire MACINTOSH hard drive ?
      Request: If you cite folders in your response please be explicit as to the path.
      Thanks in advance.
        • 1. Re: Mac to GoDaddy Linux Zend Deployment problems
          David_F57 Level 5
          Hi Dan,
          Sorry I couldn't have been more help earlier, and can't really help with what appears to be a difference between how windows/macs do things.
          Hopefully one of the Adobe guru's that works on a mac(not one with windows installed ) can explain where the fml/model descriptor is on a mac.
          David.
          • 2. Re: Mac to GoDaddy Linux Zend Deployment problems
            Thanks for the effort big time tho
            • 3. Re: Mac to GoDaddy Linux Zend Deployment problems
              Gaurav P(Adobe) Level 2
              "Uncommented and set zend_path to absolute path ( http://www.danielpride.com/ZenFrameworks )
              The path that needs to be mentioned in amf_config.ini has to be directory paths and not urls pointing to them.
              So if you webroot is C:/xxx/yyy on your drive then that needs to be mentioned.
              However, in your case since the path is on the GoDaddy server instead of a local system, you can give relative paths.
              This relative path must be relative to the location of gateway.php file.
              So if your gateway.php is in say xxx folder which is directory under the server root, then your webroot path will be:
              webroot=../
              also if your zendFramework in placed directly under the server root, then you need not give zend_path. Just comment it using ';'
              The fml file is located under the '.model' folder of your eclipse project (note: it is not under the bin-debug or output folder). Also the fml file is only used for design time in FlashBuilder and has no effect on runtime flex application.
              Hope this helps,
              Gaurav
              • 4. Re: Mac to GoDaddy Linux Zend Deployment problems
                Thank you so much for getting back to me but I still am getting
                Send failed
                Channel.Connect.Failed error NetConnection.Call.BadVersion: : url: 'http://www.danielpride.com/Vehicles3/gateway.php'
                My amf config looks like this (I edited "debug" out of the last line, no one mentioned it but it does not work either way
                [zend]
                ;set the absolute location path of webroot directory, example:
                ;Windows: C:\apache\www
                ;MAC/UNIX: /user/apache/www
                webroot =../*
                allation directory, example:
                ;Windows: C:\apache\PHPFrameworks\ZendFramework
                ;MAC/UNIX: /user/apache/PHPFrameworks/ZendFramework
                ;zend_path =
                [zendamf]
                amf.production = true
                amf.directories[]=Vehicles3/services
                The steps I am taking are as follows (note it works great on localhost, I just build and do the following
                     copy  ZendFramework/  to  server root
                     reset the constants for the new server in the include file for the services
                            Set Webroot to ( ../* )
                Dan
                • 5. Re: Mac to GoDaddy Linux Zend Deployment problems
                  You need not add * to the path
                  Just write webroot =../
                  - Gaurav
                  • 6. Re: Mac to GoDaddy Linux Zend Deployment problems
                    Thats embarrasing Too little sleep I guess.
                    Anyway, removed it and still get the same error ?
                    • 7. Re: Mac to GoDaddy Linux Zend Deployment problems
                      On just trying to open up http://www.danielpride.com/Vehicles3/gateway.php on browser will give you any loading errors.
                      I see,
                      Warning: require_once(Zend/Loader/Autoloader.php) : failed to open stream: No such file or directory in /home/content/d/a/n/danielpride/html/_DanielPride/Vehicles3/gateway.php on line 27
                      Fatal error: require_once() : Failed opening required 'Zend/Loader/Autoloader.php' (include_path='.:/usr/local/php5/lib/php:../_DanielPride/') in /home/content/d/a/n/danielpride/html/_DanielPride/Vehicles3/gateway.php on line 27
                      Which means that Zend is not loading.
                      But as you see you have now got the actual path described in the error message.
                      As an alternate solution, you can use this.
                      Try making webroot= /home/content/d/a/n/danielpride/html/_DanielPride
                      Or,  zend_path = /home/content/d/a/n/danielpride/html/_DanielPride/ZendFramework/library   (uncomment and make sure that this is where you installed Zend).
                      - Gaurav
                      • 8. Re: Mac to GoDaddy Linux Zend Deployment problems
                        Ok progress
                        Sorry to be such an idiot, REALLY thank you for the time.
                        Newbie to Zend and very tired (impatient client waiting)
                        I am now getting
                        Zend Amf Endpoint
                        Fatal error:  Class 'Zend_Exception' not found in
                        /home/content/d/a/n/danielpride/html/_DanielPride/ZendFramework/library/Zend/Exception.php on line
                        35
                        • 9. Re: Mac to GoDaddy Linux Zend Deployment problems
                          This is my phpini file
                          [Zend]
                          zend_optimizer.optimization_level=15
                          zend_extension_manager.optimizer=/usr/local/Zend/lib/Optimizer-3.3.3
                          zend_extension_manager.optimizer_ts=/usr/local/Zend/lib/Optimizer_TS-3.3.3
                          zend_extension=/usr/local/Zend/lib/Optimizer-3.3.3/ZendExtensionManager.so
                          zend_extension_ts=/usr/local/Zend/lib/Optimizer_TS-3.3.3/ZendExtensionManager_TS.so
                          • 10. Re: Mac to GoDaddy Linux Zend Deployment problems
                            Ok. Since you are getting Zend Amf Endpoint, your connection to Zend is successful
                            But you should never have got the mentioned error.
                            /home/content/d/a/n/danielpride/html/_DanielPride/ZendFramework/library/Zend/Exc eption.php on line
                            35
                            The error path says "Exc eption.php" (mark the space in between), is it a typo?
                            Can you check if you installed the mentioned  php file, and other similar folders.
                            If you still can't get this up, we can have a connect meeting.
                            Please send me a mail on GAURAVP AT ADOBE DOT COM
                            - Gaurav
                            • 11. Re: Mac to GoDaddy Linux Zend Deployment problems
                              Thank You
                              Your help was awesome
                              Sent it out.... going to bed now
                              • 12. Re: Mac to GoDaddy Linux Zend Deployment problems
                                David_F57 Level 5
                                Hi Dan
                                Also make sure that your provider is using at least php 5.2.4 preferable 5.3  as I think it won't be long before zendamf will require that.
                                David.
