6 Replies Latest reply on Jan 28, 2010 1:22 PM by NotALamer
    how do i figure out what layer is being used in the script listener log?
    NotALamer
      I recorded a 'Modify Color Fill Layer' action into the ScriptingListenerJS.log file, and I can sort of understand the output, but how do I tell what layer the style is being changed for?
        • 1. Re: how do i figure out what layer is being used in the script listener log?
          Michael L Hale Level 5
          It would help to see the code, but scriptlistener can reference the layer by name, index, or enumeration( ie target ).
          • 2. Re: how do i figure out what layer is being used in the script listener log?
            NotALamer Level 1
            var idsetd = charIDToTypeID( "setd" );
                var desc9 = new ActionDescriptor();
                var idnull = charIDToTypeID( "null" );
                    var ref3 = new ActionReference();
                    var idcontentLayer = stringIDToTypeID( "contentLayer" );
                    var idOrdn = charIDToTypeID( "Ordn" );
                    var idTrgt = charIDToTypeID( "Trgt" );
                    ref3.putEnumerated( idcontentLayer, idOrdn, idTrgt );
                desc9.putReference( idnull, ref3 );
                var idT = charIDToTypeID( "T   " );
                    var desc10 = new ActionDescriptor();
                    var idClr = charIDToTypeID( "Clr " );
                        var desc11 = new ActionDescriptor();
                        var idRd = charIDToTypeID( "Rd  " );
                        desc11.putDouble( idRd, 255.000000 );
                        var idGrn = charIDToTypeID( "Grn " );
                        desc11.putDouble( idGrn, 222.630358 );
                        var idBl = charIDToTypeID( "Bl  " );
                        desc11.putDouble( idBl, 140.000007 );
                    var idRGBC = charIDToTypeID( "RGBC" );
                    desc10.putObject( idClr, idRGBC, desc11 );
                var idsolidColorLayer = stringIDToTypeID( "solidColorLayer" );
                desc9.putObject( idT, idsolidColorLayer, desc10 );
            executeAction( idsetd, desc9, DialogModes.NO );
            I would like to be able to apply this action to an array of layers that I constructed earlier.
            • 3. Re: how do i figure out what layer is being used in the script listener log?
              First I would clean up the scriptlistener code and turn it into a function. Then do something like this.
              // make your array of solidfill layers however you like
              var l1 = activeDocument.layers.getByName( 'Color Fill 1' );
              var l2 = activeDocument.layers.getByName( 'Color Fill 2' );
              var l3 = activeDocument.layers.getByName( 'Color Fill 3' );
              var layers = [ l1, l2, l3 ];
              // iterate the array calling the scriptlistener function
              for( l = 0;l< layers.length; l++ ){
                   setFillColorByName( layers[ l ].name );
              function setFillColorByName( name ){
                  var desc = new ActionDescriptor();
                  var ref = new ActionReference();
                      ref.putName( stringIDToTypeID( "contentLayer" ), name );
                  desc.putReference( charIDToTypeID( "null" ), ref );
                      var colorDesc = new ActionDescriptor();
                          var rgbDesc = new ActionDescriptor();
                          rgbDesc.putDouble( charIDToTypeID( "Rd  " ), 255.000000 );
                          rgbDesc.putDouble( charIDToTypeID( "Grn " ), 222.630358 );
                          rgbDesc.putDouble( charIDToTypeID( "Bl  " ), 140.000007 );
                      colorDesc.putObject( charIDToTypeID( "Clr " ), charIDToTypeID( "RGBC" ), rgbDesc );
                  desc.putObject( charIDToTypeID( "T   " ), stringIDToTypeID( "solidColorLayer" ), colorDesc );
                   executeAction( charIDToTypeID( "setd" ), desc, DialogModes.NO );
              • 4. Re: how do i figure out what layer is being used in the script listener log?
                NotALamer Level 1
                Awesome that worked like a charm, thanks! Is there a reference somewhere for how ActionDescriptor and ActionReference work?
                • 5. Re: how do i figure out what layer is being used in the script listener log?
                  No, not really. The user guide lists the properties and methods for ActionDescriptor, Action Reference, and Action List. But doesn't explain how to use them other than installing the plugin.
                  • 6. Re: how do i figure out what layer is being used in the script listener log?
                    NotALamer Level 1
                    Oh well, I think I have a pretty good idea from your post, thanks again.
