2 Replies Latest reply on Jan 29, 2010 10:59 AM by shipmast3r
    IListItemRenderer & SpriteVisualElement on nightly build
    shipmast3r
      Hi everyone,
      I just switched from the beta 2 sdk to the nightly build, I am using flex_sdk_4.0.0.13827. I am running into problems with a list item renderer I have, it's an mxml that implements IListItemRenderer as follows:
      <s:Group
          implements="mx.controls.listClasses.IListItemRenderer"
          xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx"
          useHandCursor="true"
          buttonMode="true"
          width="100"
          height="100">
      And then inside this group, there is
      <s:SpriteVisualElement id="reflectionSprite" width="100%" height="100%" scaleY="-1"
                                 cacheAsBitmap="true"
                                 mask="{reflectionGradientSprite}"/>
          <s:SpriteVisualElement id="reflectionGradientSprite" width="100%" height="100%"
                                 scaleY="-1"
                                 cacheAsBitmap="true"/>
      When this renderer gets called, I get the error
      Error: MXML element reflectionSprite.reflectionGradientSprite can only have one parent.
          at spark.components::Group/setMXMLContent()[E:\dev\4.0.0\frameworks\projects\spark\src\spark \components\Group.as:510]
          at spark.components::Group/createChildren()[E:\dev\4.0.0\frameworks\projects\spark\src\spark \components\Group.as:734]
          at mx.core::UIComponent/initialize()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\ UIComponent.as:7250]
      I am assuming this is because the mask is being used multiple times in the list item renderer, Is this a by-design change of behavior for using masks in Sprites?
      Thanks.
